cesium-native 0.61.0
CesiumGltf::ImageAsset Struct Referencefinal
A 2D image asset, including its pixel data. The image may have mipmaps, and it may be encoded in a GPU compression format. More...
#include <CesiumGltf/ImageAsset.h>
Inheritance diagram for CesiumGltf::ImageAsset:
CesiumUtility::SharedAsset< ImageAsset > CesiumUtility::ExtensibleObject
 ImageAsset ()=default
 Constructs an empty image asset.
void changeNumberOfChannels (int32_t newChannels, std::byte defaultValue=std::byte{0})
 Converts this image to the given number of channels.
 Gets the size of this asset, in bytes.
- Public Member Functions inherited from CesiumUtility::SharedAsset< ImageAsset >
void addReference () const noexcept
void releaseReference () const noexcept
const IDepotOwningAsset< ImageAsset > * getDepot () const
 Gets the shared asset depot that owns this asset, or nullptr if this asset is independent of an asset depot.
const JsonValuegetGenericExtension (const std::string &extensionName) const noexcept
JsonValuegetGenericExtension (const std::string &extensionName) noexcept
int32_t width = 0
 The width of the image in pixels.
int32_t height = 0
 The height of the image in pixels.
int32_t channels = 4
 The number of channels per pixel.
int32_t bytesPerChannel = 1
 The number of bytes per channel.
GpuCompressedPixelFormat compressedPixelFormat
 The gpu compressed pixel format for this image or NONE if it is not compressed.
std::vector< ImageAssetMipPositionmipPositions
 The offset of each mip in the pixel data.
std::vector< std::byte > pixelData
 The pixel data.
int64_t sizeBytes = -1
 The effective size of this image, in bytes, for estimating resource usage for caching purposes.
Definition at line 32 of file ImageAsset.h.
◆ changeNumberOfChannels()
void CesiumGltf::ImageAsset::changeNumberOfChannels ( int32_t newChannels,
std::byte defaultValue = std::byte{0} )
If the new channel count is lower than the current channel count (for example, RGBA -> RG), the conversion happens in-place and the extra channels' values are dropped. If the new channel count is greater than the current channel count (for example, RG -> RGBA), a new pixelData buffer is allocated and the missing channels are filled with defaultValue.
newChannelsThe new number of channels for this image.
defaultValueThe default value for missing channels when increasing the channel count.
Warning
Currently only works with one-byte-per-channel images.
int64_t CesiumGltf::ImageAsset::getSizeBytes ( ) const
If sizeBytes is greater than or equal to zero, it is returned. Otherwise, the size of the pixelData array is returned.
Definition at line 145 of file ImageAsset.h.
◆ bytesPerChannel
int32_t CesiumGltf::ImageAsset::bytesPerChannel = 1
Definition at line 52 of file ImageAsset.h.
◆ channels
int32_t CesiumGltf::ImageAsset::channels = 4
Definition at line 47 of file ImageAsset.h.
◆ compressedPixelFormat
GpuCompressedPixelFormat CesiumGltf::ImageAsset::compressedPixelFormat
Initial value:
Definition at line 58 of file ImageAsset.h.
◆ height
int32_t CesiumGltf::ImageAsset::height = 0
Definition at line 42 of file ImageAsset.h.
◆ mipPositions
std::vector<ImageAssetMipPosition> CesiumGltf::ImageAsset::mipPositions
A list of the positions of each mip's data within the overall pixel buffer. The first element will be the full image, the second will be the second biggest and etc. If this is empty, assume the entire buffer is a single image, the mip map will need to be generated on the client in this case.
Definition at line 69 of file ImageAsset.h.
◆ pixelData
std::vector<std::byte> CesiumGltf::ImageAsset::pixelData
The pixel data.
This will be the raw pixel data when compressedPixelFormat is std::nullopt. Otherwise, this buffer will store the compressed pixel data in the specified format.
If mipPositions is not empty, this buffer will contains multiple mips back-to-back.
When this is an uncompressed texture: -The pixel data is consistent with the stb image library.
-For a correctly-formed image, the size of the array will be width * height * channels * bytesPerChannel bytes. There is no padding between rows or columns of the image, regardless of format.
-The channels and their meaning are as follows:
Number of Channels Channel Order and Meaning
1 grey
2 grey, alpha
3 red, green, blue
4 red, green, blue, alpha
Definition at line 98 of file ImageAsset.h.
◆ sizeBytes
int64_t CesiumGltf::ImageAsset::sizeBytes = -1
When this value is less than zero (the default), the size of this image should be assumed to equal the size of the pixelData array. When it is greater than or equal to zero, the specified size should be used instead. For example, the overridden size may account for:
  • The pixelData being cleared during the load process in order to save memory.
  • The cost of any renderer resources (e.g., GPU textures) created for this image.
Definition at line 113 of file ImageAsset.h.
◆ width
int32_t CesiumGltf::ImageAsset::width = 0
Definition at line 37 of file ImageAsset.h.
