CesiumGltf::PropertyTextureProperty Struct Referencefinal
A texture containing property values. More...
#include <CesiumGltf/PropertyTextureProperty.h>
Inheritance diagram for CesiumGltf::PropertyTextureProperty:
CesiumGltf::TextureInfo CesiumUtility::ExtensibleObject
- Public Member Functions inherited from CesiumGltf::TextureInfo
std::vector< int64_t > channels = {0}
 Texture channels containing property values, identified by index. The values may be packed into multiple channels if a single channel does not have sufficient bit depth. The values are packed in little-endian order.
std::optional< CesiumUtility::JsonValue > offset
 An offset to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Overrides the class property's offset if both are defined.
std::optional< CesiumUtility::JsonValue > scale
 A scale to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Overrides the class property's scale if both are defined.
std::optional< CesiumUtility::JsonValue > max
 Maximum value present in the property values. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > min
 Minimum value present in the property values. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
- Public Attributes inherited from CesiumGltf::TextureInfo
int32_t index = -1
 The index of the texture.
int64_t texCoord = 0
 The set index of texture's TEXCOORD attribute used for texture coordinate mapping.
static constexpr const char * TypeName = "PropertyTextureProperty"
- Static Public Attributes inherited from CesiumGltf::TextureInfo
static constexpr const char * TypeName = "TextureInfo"
Definition at line 17 of file PropertyTextureProperty.h.
int64_t CesiumGltf::PropertyTextureProperty::getSizeBytes ( ) const
Definition at line 67 of file PropertyTextureProperty.h.
◆ channels
std::vector<int64_t> CesiumGltf::PropertyTextureProperty::channels = {0}
Definition at line 29 of file PropertyTextureProperty.h.
◆ max
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyTextureProperty::max
Definition at line 51 of file PropertyTextureProperty.h.
◆ min
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyTextureProperty::min
Definition at line 59 of file PropertyTextureProperty.h.
◆ offset
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyTextureProperty::offset
Definition at line 36 of file PropertyTextureProperty.h.
◆ scale
std::optional<CesiumUtility::JsonValue> CesiumGltf::PropertyTextureProperty::scale
Definition at line 43 of file PropertyTextureProperty.h.
const char* CesiumGltf::PropertyTextureProperty::TypeName = "PropertyTextureProperty"
Definition at line 21 of file PropertyTextureProperty.h.
