ExtensionKhrTextureTransform.h
8#include <cstdint>
9#include <optional>
10#include <vector>
11
12namespace CesiumGltf {
17struct CESIUMGLTF_API ExtensionKhrTextureTransform final
22 static constexpr const char* TypeName = "ExtensionKhrTextureTransform";
25 static constexpr const char* ExtensionName = "KHR_texture_transform";
26
31 std::vector<double> offset = {0, 0};
32
37 double rotation = 0;
38
42 std::vector<double> scale = {1, 1};
43
48 std::optional<int64_t> texCoord;
49
56 int64_t getSizeBytes() const {
57 int64_t accum = 0;
58 accum += int64_t(sizeof(ExtensionKhrTextureTransform));
60 int64_t(sizeof(CesiumUtility::ExtensibleObject));
61 accum += int64_t(sizeof(double) * this->offset.capacity());
62 accum += int64_t(sizeof(double) * this->scale.capacity());
63 return accum;
64 }
65};
66} // namespace CesiumGltf
glTF extension that enables shifting and scaling UV coordinates on a per-texture basis
double rotation
Rotate the UVs by this many radians counter-clockwise around the origin.
std::optional< int64_t > texCoord
Overrides the textureInfo texCoord value if supplied, and if this extension is supported.
std::vector< double > scale
The scale factor applied to the components of the UV coordinates.
std::vector< double > offset
The offset of the UV coordinate origin as a factor of the texture dimensions.
