A copy of an array element of a PropertyTableProperty or PropertyTextureProperty. More...
#include <CesiumGltf/PropertyArrayView.h>
| PropertyArrayCopy () | |
| Constructs an empty array copy. | |
| PropertyArrayCopy (const std::vector< ElementType > &values) noexcept | |
| Constructs an array copy from a vector. | |
| PropertyArrayCopy (PropertyArrayCopy &&)=default | |
| Default move constructor. | |
| PropertyArrayCopy & | operator= (PropertyArrayCopy &&)=default |
| Default move assignment operator. | |
| PropertyArrayCopy (std::vector< std::byte > &&buffer) noexcept | |
| Creates a new PropertyArrayCopy directly from a buffer of bytes, which will be moved into this copy. | |
| PropertyArrayCopy (const PropertyArrayCopy &rhs) | |
| Copy constructor. | |
| PropertyArrayCopy & | operator= (const PropertyArrayCopy &rhs) |
| Copy assignment operator. | |
| const ElementType & | operator[] (int64_t index) const noexcept |
Returns the ElementType at the given index from this copy. | |
| int64_t | size () const noexcept |
| The number of elements in this array. | |
| auto | begin () |
The begin iterator. | |
| auto | end () |
The end iterator. | |
| auto | begin () const |
| auto | end () const |
| const PropertyArrayView< ElementType > & | view () const |
| Obtains a PropertyArrayView over the contents of this copy. | |
| PropertyArrayView< ElementType > | toViewAndExternalBuffer (std::vector< std::byte > &outBuffer) && |
| Obtains a buffer and view from the copied data, leaving this PropertyArrayCopy empty. | |
Whereas PropertyArrayView is a pointer to data stored in a separate place, a PropertyArrayCopy owns the data that it's viewing.
Provides utility to retrieve the data stored in the array of elements via the array index operator.
Definition at line 77 of file PropertyArrayView.h.
Definition at line 82 of file PropertyArrayView.h.
inlinenoexcept |
| values | The vector containing the values. |
Definition at line 89 of file PropertyArrayView.h.
inlinenoexcept |
Definition at line 109 of file PropertyArrayView.h.
Copy constructor.
Definition at line 113 of file PropertyArrayView.h.
The begin iterator.
Definition at line 137 of file PropertyArrayView.h.
The begin iterator.
Definition at line 141 of file PropertyArrayView.h.
The end iterator.
Definition at line 139 of file PropertyArrayView.h.
The end iterator.
Definition at line 143 of file PropertyArrayView.h.
Definition at line 117 of file PropertyArrayView.h.
inlinenoexcept |
| index | The index to obtain. |
ElementType at that index from the internal view. Definition at line 129 of file PropertyArrayView.h.
inlinenoexcept |
Definition at line 134 of file PropertyArrayView.h.
| outBuffer | The destination where this copy's internal buffer will be moved to. |
Definition at line 158 of file PropertyArrayView.h.
Definition at line 148 of file PropertyArrayView.h.
