ClassProperty.h
9#include <cstdint>
10#include <optional>
11#include <string>
12
13namespace CesiumGltf {
17struct CESIUMGLTF_API ClassProperty final
22 static constexpr const char* TypeName = "ClassProperty";
23
27 struct Type {
29 inline static const std::string SCALAR = "SCALAR";
30
32 inline static const std::string VEC2 = "VEC2";
33
35 inline static const std::string VEC3 = "VEC3";
36
38 inline static const std::string VEC4 = "VEC4";
39
41 inline static const std::string MAT2 = "MAT2";
42
44 inline static const std::string MAT3 = "MAT3";
45
47 inline static const std::string MAT4 = "MAT4";
48
50 inline static const std::string STRING = "STRING";
51
53 inline static const std::string BOOLEAN = "BOOLEAN";
54
56 inline static const std::string ENUM = "ENUM";
57 };
58
65 inline static const std::string INT8 = "INT8";
66
68 inline static const std::string UINT8 = "UINT8";
69
71 inline static const std::string INT16 = "INT16";
72
74 inline static const std::string UINT16 = "UINT16";
75
77 inline static const std::string INT32 = "INT32";
78
80 inline static const std::string UINT32 = "UINT32";
81
83 inline static const std::string INT64 = "INT64";
84
86 inline static const std::string UINT64 = "UINT64";
87
89 inline static const std::string FLOAT32 = "FLOAT32";
90
92 inline static const std::string FLOAT64 = "FLOAT64";
93 };
94
98 std::optional<std::string> name;
99
103 std::optional<std::string> description;
104
111 std::string type = Type::SCALAR;
112
120 std::optional<std::string> componentType;
121
126 std::optional<std::string> enumType;
127
133 bool array = false;
134
139 std::optional<int64_t> count;
140
149 bool normalized = false;
150
156 std::optional<CesiumUtility::JsonValue> offset;
157
163 std::optional<CesiumUtility::JsonValue> scale;
164
171 std::optional<CesiumUtility::JsonValue> max;
172
179 std::optional<CesiumUtility::JsonValue> min;
180
188 bool required = false;
189
197 std::optional<CesiumUtility::JsonValue> noData;
198
205 std::optional<CesiumUtility::JsonValue> defaultProperty;
206
211 std::optional<std::string> semantic;
212
219 int64_t getSizeBytes() const {
220 int64_t accum = 0;
221 accum += int64_t(sizeof(ClassProperty));
223 int64_t(sizeof(CesiumUtility::ExtensibleObject));
224 if (this->name) {
225 accum += int64_t(this->name->capacity() * sizeof(char));
226 }
227 if (this->description) {
228 accum += int64_t(this->description->capacity() * sizeof(char));
229 }
230 if (this->enumType) {
231 accum += int64_t(this->enumType->capacity() * sizeof(char));
232 }
233 if (this->semantic) {
234 accum += int64_t(this->semantic->capacity() * sizeof(char));
235 }
236 return accum;
237 }
238};
239} // namespace CesiumGltf
Known values for The datatype of the element's components. Only applicable to SCALAR,...
INT32
INT16
FLOAT32
INT8
INT64
UINT8
UINT32
FLOAT64
UINT16
UINT64
Known values for The element type.
STRING
MAT4
VEC4
VEC3
ENUM
MAT3
MAT2
VEC2
SCALAR
BOOLEAN
std::optional< std::string > semantic
An identifier that describes how this property should be interpreted. The semantic cannot be used by ...
bool normalized
Specifies whether integer values are normalized. Only applicable to SCALAR, VECN, and MATN types with...
std::optional< std::string > componentType
The datatype of the element's components. Only applicable to SCALAR, VECN, and MATN types.
std::optional< int64_t > count
The number of array elements. May only be defined when array is true.
A scale to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the compone...
bool array
Whether the property is an array. When count is defined the property is a fixed-length array....
An offset to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the compo...
The description of the property.
std::optional< CesiumUtility::JsonValue > noData
A noData value represents missing data — also known as a sentinel value — wherever it appears....
std::string type
The element type.
Minimum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types....
bool required
If required, the property must be present in every entity conforming to the class....
std::optional< std::string > enumType
Enum ID as declared in the enums dictionary. Required when type is ENUM.
The name of the property, e.g. for display purposes.
std::optional< CesiumUtility::JsonValue > defaultProperty
A default value to use when encountering a noData value or an omitted property. The value is given in...
Maximum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types....
