TextureView.h
3#include <CesiumGltf/KhrTextureTransform.h>
4#include <CesiumGltf/Sampler.h>
5#include <CesiumGltf/TextureInfo.h>
6#include <CesiumImage/ImageAsset.h>
7#include <CesiumUtility/IntrusivePointer.h>
9#include <vector>
10
11namespace CesiumGltf {
12
13struct Model;
14
49
94
99public:
103 TextureView() noexcept;
104
114 const Model& model,
115 const TextureInfo& textureInfo,
116 const TextureViewOptions& options = TextureViewOptions()) noexcept;
117
131 const Sampler& sampler,
132 const CesiumImage::ImageAsset& image,
133 int64_t textureCoordinateSetIndex,
134 const ExtensionKhrTextureTransform* pKhrTextureTransformExtension =
135 nullptr,
136 const TextureViewOptions& options = TextureViewOptions()) noexcept;
137
144 return this->_textureViewStatus;
145 }
146
155 int64_t getTexCoordSetIndex() const noexcept {
156 if (this->_applyTextureTransform && this->_textureTransform) {
157 return this->_textureTransform->getTexCoordSetIndex().value_or(
158 this->_texCoordSetIndex);
159 }
160 return this->_texCoordSetIndex;
161 }
162
170 const Sampler* getSampler() const noexcept { return this->_pSampler; }
171
180 const CesiumImage::ImageAsset* getImage() const noexcept {
181 if (this->_pImageCopy) {
182 return this->_pImageCopy.get();
183 }
184 return this->_pImage.get();
185 }
186
199 std::optional<KhrTextureTransform> getTextureTransform() const noexcept {
200 return this->_textureTransform;
201 }
202
209 std::vector<uint8_t> sampleNearestPixel(
210 double u,
211 double v,
212 const std::vector<int64_t>& channels) const noexcept;
213
214private:
215 TextureViewStatus _textureViewStatus;
216
217 const Sampler* _pSampler;
219 int64_t _texCoordSetIndex;
220
221 bool _applyTextureTransform;
222 std::optional<KhrTextureTransform> _textureTransform;
223
225};
226} // namespace CesiumGltf
const Sampler * getSampler() const noexcept
Get the sampler describing how to sample the data from the property's texture.
const CesiumImage::ImageAsset * getImage() const noexcept
Get the image containing this property's data. If this view was constructed with options....
std::optional< KhrTextureTransform > getTextureTransform() const noexcept
Get the KHR_texture_transform for this texture if it exists.
TextureViewStatus getTextureViewStatus() const noexcept
Get the status of this texture view.
Constructs an empty, uninitialized texture view.
Get the texture coordinate set index for this view. If this view was constructed with options....
std::vector< uint8_t > sampleNearestPixel(double u, double v, const std::vector< int64_t > &channels) const noexcept
Samples the image at the specified texture coordinates using NEAREST pixel filtering,...
TextureViewStatus
Indicates the status of a texture view.
Definition TextureView.h:57
@ ErrorInvalidBytesPerChannel
The image for this texture has channels that take up more than a byte. Only single-byte channels are ...
Definition TextureView.h:92
@ ErrorEmptyImage
This feature ID texture has an empty image.
@ ErrorUninitialized
This view has not yet been initialized.
@ ErrorInvalidSampler
This feature ID texture has a sampler index that doesn't exist in the glTF.
@ ErrorInvalidImage
This feature ID texture has an image index that doesn't exist in the glTF.
@ ErrorInvalidTexture
This feature ID texture has a texture index that doesn't exist in the glTF.
@ Valid
This accessor is valid and ready to use.
Classes that support reading, decoding, and manipulating images.
Definition ImageAsset.h:11
glTF extension that enables shifting and scaling UV coordinates on a per-texture basis
Definition Model.h:14
Texture sampler properties for filtering and wrapping modes.
Definition Sampler.h:14
Reference to a texture.
Definition TextureInfo.h:14
Describes options for constructing a view on a glTF texture.
Definition TextureView.h:18
bool makeImageCopy
Whether to copy the input image.
Definition TextureView.h:47
bool applyKhrTextureTransformExtension
Whether to automatically apply the KHR_texture_transform extension to the texture view,...
Definition TextureView.h:37
A 2D image asset, including its pixel data. The image may have mipmaps, and it may be encoded in a GP...
Definition ImageAsset.h:33
