Describes options for constructing a view on a glTF texture. More...
#include <CesiumGltf/TextureView.h>
| bool | applyKhrTextureTransformExtension = false |
Whether to automatically apply the KHR_texture_transform extension to the texture view, if it exists. | |
| bool | makeImageCopy = false |
| Whether to copy the input image. | |
Definition at line 18 of file TextureView.h.
| bool CesiumGltf::TextureViewOptions::applyKhrTextureTransformExtension = false |
A glTF texture may contain the KHR_texture_transform extension, which transforms the texture coordinates used to sample the texture. The extension may also override the TEXCOORD set index that was specified by the original texture info.
If a view is constructed with applyKhrTextureTransformExtension set to true, it should automatically apply the texture transform to any UV coordinates used to sample the texture. If the extension defines its own TEXCOORD set index, it will override the original value.
Otherwise, if the flag is set to false, UVs will not be transformed and the original TEXCOORD set index will be preserved. The extension's values may still be retrieved using getTextureTransform, if desired.
Definition at line 37 of file TextureView.h.
| bool CesiumGltf::TextureViewOptions::makeImageCopy = false |
By default, a view is constructed on the input glTF image without copying its pixels. This can be problematic for clients that move or delete the original glTF model. When this flag is true, the view will manage its own copy of the pixel data to avoid such issues.
Definition at line 47 of file TextureView.h.
