glTF extension that enables shifting and scaling UV coordinates on a per-texture basis More...
#include <CesiumGltf/ExtensionKhrTextureTransform.h>
| std::vector< double > | offset = {0, 0} |
| The offset of the UV coordinate origin as a factor of the texture dimensions. | |
| double | rotation = 0 |
| Rotate the UVs by this many radians counter-clockwise around the origin. | |
| std::vector< double > | scale = {1, 1} |
| The scale factor applied to the components of the UV coordinates. | |
| std::optional< int64_t > | texCoord |
| Overrides the textureInfo texCoord value if supplied, and if this extension is supported. | |
| static constexpr const char * | TypeName = "ExtensionKhrTextureTransform" |
| static constexpr const char * | ExtensionName = "KHR_texture_transform" |
Definition at line 17 of file ExtensionKhrTextureTransform.h.
Definition at line 56 of file ExtensionKhrTextureTransform.h.
Definition at line 25 of file ExtensionKhrTextureTransform.h.
| std::vector<double> CesiumGltf::ExtensionKhrTextureTransform::offset = {0, 0} |
Definition at line 31 of file ExtensionKhrTextureTransform.h.
| double CesiumGltf::ExtensionKhrTextureTransform::rotation = 0 |
Definition at line 37 of file ExtensionKhrTextureTransform.h.
| std::vector<double> CesiumGltf::ExtensionKhrTextureTransform::scale = {1, 1} |
Definition at line 42 of file ExtensionKhrTextureTransform.h.
| std::optional<int64_t> CesiumGltf::ExtensionKhrTextureTransform::texCoord |
Definition at line 48 of file ExtensionKhrTextureTransform.h.
Definition at line 22 of file ExtensionKhrTextureTransform.h.
