Indicates the status of a property texture property view. More...
#include <CesiumGltf/PropertyTexturePropertyView.h>
| static const int | ErrorInvalidPropertyTexture = 15 |
| This property view was initialized from an invalid PropertyTexture. | |
| static const int | ErrorUnsupportedProperty = 16 |
| This property view is associated with a ClassProperty of an unsupported type. | |
| static const int | ErrorInvalidTexture = 17 |
| This property view does not have a valid texture index. | |
| static const int | ErrorInvalidSampler = 18 |
| This property view does not have a valid sampler index. | |
| static const int | ErrorInvalidImage = 19 |
| This property view does not have a valid image index. | |
| static const int | ErrorEmptyImage = 20 |
| This property is viewing an empty image. | |
| static const int | ErrorInvalidBytesPerChannel = 21 |
| This property uses an image with multi-byte channels. Only single-byte channels are supported. | |
| static const int | ErrorInvalidChannels = 22 |
| The channels of this property texture property are invalid. Channels must be in the range 0-N, where N is the number of available channels in the image. There must be a minimum of one channel. Although more than four channels can be defined for specialized texture formats, this implementation only supports four channels max. | |
| static const int | ErrorChannelsAndTypeMismatch = 23 |
| The channels of this property texture property do not provide the exact number of bytes required by the property type. This may be because an incorrect number of channels was provided, or because the image itself has a different channel count / byte size than expected. | |
Static Public Attributes inherited from CesiumGltf::PropertyViewStatus | |
| static const PropertyViewStatusType | Valid = 0 |
| This property view is valid and ready to use. | |
| static const PropertyViewStatusType | EmptyPropertyWithDefault = 1 |
| This property view does not contain any data, but specifies a default value. This happens when a class property is defined with a default value and omitted from an instance of the class's collective properties. In this case, it is not possible to retrieve the raw data from a property, but its default value will be accessible. | |
| static const PropertyViewStatusType | ErrorNonexistentProperty = 2 |
| This property view is trying to view a property that does not exist. | |
| static const PropertyViewStatusType | ErrorTypeMismatch = 3 |
| This property view's type does not match what is specified in ClassProperty::type. | |
| static const PropertyViewStatusType | ErrorComponentTypeMismatch = 4 |
| This property view's component type does not match what is specified in ClassProperty::componentType. | |
| static const PropertyViewStatusType | ErrorArrayTypeMismatch = 5 |
| This property view differs from what is specified in ClassProperty::array. | |
| static const PropertyViewStatusType | ErrorInvalidNormalization = 6 |
| This property says it is normalized, but it does not have an integer component type. | |
| static const PropertyViewStatusType | ErrorNormalizationMismatch = 7 |
| This property view's normalization differs from what is specified in ClassProperty::normalized. | |
| static const PropertyViewStatusType | ErrorInvalidOffset = 8 |
| The property provided an invalid offset value. | |
| static const PropertyViewStatusType | ErrorInvalidScale = 9 |
| The property provided an invalid scale value. | |
| static const PropertyViewStatusType | ErrorInvalidMax = 10 |
| The property provided an invalid maximum value. | |
| static const PropertyViewStatusType | ErrorInvalidMin = 11 |
| The property provided an invalid minimum value. | |
| static const PropertyViewStatusType | ErrorInvalidNoDataValue = 12 |
| The property provided an invalid "no data" value. | |
| static const PropertyViewStatusType | ErrorInvalidDefaultValue = 13 |
| The property provided an invalid default value. | |
| static const PropertyViewStatusType | ErrorInvalidEnum = 14 |
| The property provided an invalid enum value. | |
The PropertyTexturePropertyView constructor always completes successfully. However it may not always reflect the actual content of the corresponding property texture property. This enumeration provides the reason.
Definition at line 27 of file PropertyTexturePropertyView.h.
static |
Definition at line 82 of file PropertyTexturePropertyView.h.
static |
Definition at line 59 of file PropertyTexturePropertyView.h.
static |
Definition at line 65 of file PropertyTexturePropertyView.h.
static |
Definition at line 74 of file PropertyTexturePropertyView.h.
static |
Definition at line 54 of file PropertyTexturePropertyView.h.
static |
Definition at line 33 of file PropertyTexturePropertyView.h.
static |
Definition at line 49 of file PropertyTexturePropertyView.h.
static |
Definition at line 44 of file PropertyTexturePropertyView.h.
static |
Definition at line 39 of file PropertyTexturePropertyView.h.
