Options for loading raster overlays. More...
#include <CesiumRasterOverlays/RasterOverlay.h>
| int32_t | maximumSimultaneousTileLoads = 20 |
| The maximum number of overlay tiles that may simultaneously be in the process of loading. | |
| int64_t | subTileCacheBytes = static_cast<int64_t>(16 * 1024 * 1024) |
| The maximum number of bytes to use to cache sub-tiles in memory. | |
| int32_t | maximumTextureSize = 2048 |
| The maximum pixel size of raster overlay textures, in either direction. | |
| double | maximumScreenSpaceError = 2.0 |
| The maximum number of pixels of error when rendering this overlay. This is used to select an appropriate level-of-detail. | |
| CesiumImage::Ktx2TranscodeTargets | ktx2TranscodeTargets |
| For each possible input transmission format, this struct names the ideal target gpu-compressed pixel format to transcode to. | |
| std::function< void(const RasterOverlayLoadFailureDetails &)> | loadErrorCallback |
| A callback function that is invoked when a raster overlay resource fails to load. | |
| bool | showCreditsOnScreen = false |
| Whether or not to display the credits on screen. | |
| std::any | rendererOptions |
| Arbitrary data that will be passed to Cesium3DTilesSelection::IPrepareRendererResources::prepareRasterInLoadThread, for example, data to control the per-raster overlay client-specific texture properties. | |
| CesiumGeospatial::Ellipsoid | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 |
| The ellipsoid used for this raster overlay. | |
Definition at line 38 of file RasterOverlay.h.
| CesiumGeospatial::Ellipsoid CesiumRasterOverlays::RasterOverlayOptions::ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 |
Definition at line 120 of file RasterOverlay.h.
| CesiumImage::Ktx2TranscodeTargets CesiumRasterOverlays::RasterOverlayOptions::ktx2TranscodeTargets |
Definition at line 85 of file RasterOverlay.h.
| std::function<void(const RasterOverlayLoadFailureDetails&)> CesiumRasterOverlays::RasterOverlayOptions::loadErrorCallback |
Raster overlay resources include a Cesium ion asset endpoint or any resources required for raster overlay metadata.
This callback is invoked by the Cesium3DTilesSelection::RasterOverlayCollection when an error occurs while it is creating a tile provider for this RasterOverlay. It is always invoked in the main thread.
Definition at line 99 of file RasterOverlay.h.
| double CesiumRasterOverlays::RasterOverlayOptions::maximumScreenSpaceError = 2.0 |
When this property has its default value, 2.0, it means that raster overlay images will be sized so that, when zoomed in closest, a single pixel in the raster overlay maps to approximately 2x2 pixels on the screen.
Definition at line 79 of file RasterOverlay.h.
| int32_t CesiumRasterOverlays::RasterOverlayOptions::maximumSimultaneousTileLoads = 20 |
Definition at line 43 of file RasterOverlay.h.
| int32_t CesiumRasterOverlays::RasterOverlayOptions::maximumTextureSize = 2048 |
Images created by this overlay will be no more than this number of pixels in either direction. This may result in reduced raster overlay detail in some cases. For example, in a QuadtreeRasterOverlayTileProvider, this property will limit the number of quadtree tiles that may be mapped to a given geometry tile. The selected quadtree level for a geometry tile is reduced in order to stay under this limit.
Definition at line 69 of file RasterOverlay.h.
| std::any CesiumRasterOverlays::RasterOverlayOptions::rendererOptions |
This object is copied and given to background texture preparation threads, so it must be inexpensive to copy.
Definition at line 115 of file RasterOverlay.h.
| bool CesiumRasterOverlays::RasterOverlayOptions::showCreditsOnScreen = false |
Definition at line 104 of file RasterOverlay.h.
| int64_t CesiumRasterOverlays::RasterOverlayOptions::subTileCacheBytes = static_cast<int64_t>(16 * 1024 * 1024) |
This is used by provider types, such as QuadtreeRasterOverlayTileProvider, that have an underlying tiling scheme that may not align with the tiling scheme of the geometry tiles on which the raster overlay tiles are draped. Because a single sub-tile may overlap multiple geometry tiles, it is useful to cache loaded sub-tiles in memory in case they're needed again soon. This property controls the maximum size of that cache.
Definition at line 56 of file RasterOverlay.h.
