cesium-native 0.60.0
CesiumRasterOverlays::GeoJsonDocumentRasterOverlay Class Referencefinal
A raster overlay made from rasterizing a CesiumVectorData::GeoJsonDocument. More...
#include <CesiumRasterOverlays/GeoJsonDocumentRasterOverlay.h>
Inheritance diagram for CesiumRasterOverlays::GeoJsonDocumentRasterOverlay:
CesiumRasterOverlays::RasterOverlay CesiumUtility::ReferenceCounted< T, false >
 GeoJsonDocumentRasterOverlay (const CesiumAsync::AsyncSystem &asyncSystem, const std::string &name, const std::shared_ptr< CesiumVectorData::GeoJsonDocument > &document, const GeoJsonDocumentRasterOverlayOptions &vectorOverlayOptions, const RasterOverlayOptions &overlayOptions={})
 Creates a new GeoJsonDocumentRasterOverlay.
 GeoJsonDocumentRasterOverlay (const std::string &name, CesiumAsync::Future< std::shared_ptr< CesiumVectorData::GeoJsonDocument > > &&documentFuture, const GeoJsonDocumentRasterOverlayOptions &vectorOverlayOptions, const RasterOverlayOptions &overlayOptions={})
 Creates a new GeoJsonDocumentRasterOverlay from a future.
virtual CesiumAsync::Future< CreateTileProviderResultcreateTileProvider (const CreateRasterOverlayTileProviderParameters &parameters) const override
 Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future.
- Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay
 RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
 Creates a new instance.
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem)
 A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
const std::string & getName () const noexcept
 Gets the name of this overlay.
RasterOverlayOptionsgetOptions () noexcept
 Gets options for this overlay.
const RasterOverlayOptionsgetOptions () const noexcept
CesiumUtility::IntrusivePointer< ActivatedRasterOverlayactivate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Activates this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvidercreatePlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously.
void addReference () const
Additional Inherited Members
- Public Types inherited from CesiumRasterOverlays::RasterOverlay
using CreateTileProviderResult
 A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful.
Definition at line 48 of file GeoJsonDocumentRasterOverlay.h.
◆ GeoJsonDocumentRasterOverlay() [1/2]
CesiumRasterOverlays::GeoJsonDocumentRasterOverlay::GeoJsonDocumentRasterOverlay ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & name,
const std::shared_ptr< CesiumVectorData::GeoJsonDocument > & document,
const GeoJsonDocumentRasterOverlayOptions & vectorOverlayOptions,
const RasterOverlayOptions & overlayOptions = {} )
asyncSystemThe async system to use.
nameThe user-given name of this polygon layer.
documentThe GeoJSON document to use for the overlay.
vectorOverlayOptionsOptions to configure this GeoJsonDocumentRasterOverlay.
overlayOptionsOptions to use for this RasterOverlay.
◆ GeoJsonDocumentRasterOverlay() [2/2]
CesiumRasterOverlays::GeoJsonDocumentRasterOverlay::GeoJsonDocumentRasterOverlay ( const std::string & name,
CesiumAsync::Future< std::shared_ptr< CesiumVectorData::GeoJsonDocument > > && documentFuture,
documentFutureA future resolving into a GeoJSON document to use for the overlay.
◆ createTileProvider()
virtual CesiumAsync::Future< CreateTileProviderResult > CesiumRasterOverlays::GeoJsonDocumentRasterOverlay::createTileProvider ( const CreateRasterOverlayTileProviderParameters & parameters) const
overridevirtual
parametersThe parameters for creating the tile provider.
The future that resolves to the tile provider when it is ready, or to error details in the case of an error.
Implements CesiumRasterOverlays::RasterOverlay.
