RasterOverlay.h
3#include <CesiumAsync/AsyncSystem.h>
4#include <CesiumAsync/IAssetAccessor.h>
5#include <CesiumGeospatial/Ellipsoid.h>
6#include <CesiumImage/Ktx2TranscodeTargets.h>
7#include <CesiumRasterOverlays/Library.h>
8#include <CesiumRasterOverlays/RasterOverlayLoadFailureDetails.h>
9#include <CesiumUtility/IntrusivePointer.h>
10#include <CesiumUtility/ReferenceCounted.h>
11
12#include <nonstd/expected.hpp>
13#include <spdlog/fwd.h>
14
15#include <any>
16#include <cstddef>
17#include <functional>
18#include <memory>
19#include <optional>
20#include <string>
21
22namespace CesiumUtility {
23struct Credit;
24class CreditSystem;
25} // namespace CesiumUtility
26
27namespace CesiumRasterOverlays {
28
34
38struct CESIUMRASTEROVERLAYS_API RasterOverlayOptions {
44
56 int64_t subTileCacheBytes = static_cast<int64_t>(16 * 1024 * 1024);
57
69 int32_t maximumTextureSize = 2048;
70
80
86
100
105
116
121};
122
141 : public CesiumUtility::ReferenceCountedNonThreadSafe<RasterOverlay> {
142public:
150 const std::string& name,
151 const RasterOverlayOptions& overlayOptions = RasterOverlayOptions());
152 virtual ~RasterOverlay() noexcept;
153
164 CesiumAsync::SharedFuture<void>&
165 getAsyncDestructionCompleteEvent(const CesiumAsync::AsyncSystem& asyncSystem);
166
170 const std::string& getName() const noexcept { return this->_name; }
171
175 RasterOverlayOptions& getOptions() noexcept { return this->_options; }
176
178 const RasterOverlayOptions& getOptions() const noexcept {
179 return this->_options;
180 }
181
195 const RasterOverlayExternals& externals,
196 const CesiumGeospatial::Ellipsoid& ellipsoid
197 CESIUM_DEFAULT_ELLIPSOID) const;
198
208 const RasterOverlayExternals& externals,
209 const CesiumGeospatial::Ellipsoid& ellipsoid
210 CESIUM_DEFAULT_ELLIPSOID) const;
211
219 using CreateTileProviderResult = nonstd::expected<
222
232 const CreateRasterOverlayTileProviderParameters& parameters) const = 0;
233
234private:
235 struct DestructionCompleteDetails {
236 CesiumAsync::AsyncSystem asyncSystem;
239 };
240
241 std::string _name;
242 RasterOverlayOptions _options;
243 std::vector<CesiumUtility::Credit> _credits;
244 std::optional<DestructionCompleteDetails> _destructionCompleteDetails;
245};
246
247} // namespace CesiumRasterOverlays
A system for managing asynchronous requests and tasks.
Definition AsyncSystem.h:37
Definition Future.h:29
A promise that can be resolved or rejected by an asynchronous task.
Definition Promise.h:19
A value that will be available in the future, as produced by AsyncSystem. Unlike Future,...
Definition Ellipsoid.h:39
static const Ellipsoid WGS84
An Ellipsoid instance initialized to the WGS84 standard.
Definition Ellipsoid.h:48
A RasterOverlay that has been activated for use. While a RasterOverlayTileProvider can be used direct...
An interface between Cesium Native and the application using it, allowing Cesium Native to pass loade...
External interfaces used by a RasterOverlay.
Details on a failure while attempting to load a raster overlay tile.
Provides individual tiles for a RasterOverlay on demand.
const RasterOverlayOptions & getOptions() const noexcept
Gets options for this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > createPlaceholder(const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
Create a placeholder tile provider can be used in place of the real one while createTileProvider comp...
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent(const CesiumAsync::AsyncSystem &asyncSystem)
A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been calle...
RasterOverlay(const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
Creates a new instance.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider(const CreateRasterOverlayTileProviderParameters &parameters) const =0
Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Futu...
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > activate(const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
Activates this overlay.
RasterOverlayOptions & getOptions() noexcept
nonstd::expected< CesiumUtility::IntrusivePointer< RasterOverlayTileProvider >, RasterOverlayLoadFailureDetails > CreateTileProviderResult
A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOve...
const std::string & getName() const noexcept
Gets the name of this overlay.
Creates and manages Credit objects. Avoids repetitions and tracks which credits should be shown and w...
Classes that support asynchronous operations.
Classes for raster overlays, which allow draping massive 2D textures over a model.
Utility classes for Cesium.
ReferenceCounted< T, false > ReferenceCountedNonThreadSafe
A reference-counted base class, meant to be used with IntrusivePointer. The reference count is not th...
STL namespace.
For each possible input transmission format, this struct names the ideal target gpu-compressed pixel ...
Options for loading raster overlays.
std::any rendererOptions
Arbitrary data that will be passed to Cesium3DTilesSelection::IPrepareRendererResources::prepareRaste...
double maximumScreenSpaceError
The maximum number of pixels of error when rendering this overlay. This is used to select an appropri...
bool showCreditsOnScreen
Whether or not to display the credits on screen.
int32_t maximumSimultaneousTileLoads
std::function< void(const RasterOverlayLoadFailureDetails &)> loadErrorCallback
A callback function that is invoked when a raster overlay resource fails to load.
CesiumImage::Ktx2TranscodeTargets ktx2TranscodeTargets
CesiumGeospatial::Ellipsoid ellipsoid
The ellipsoid used for this raster overlay.
The maximum pixel size of raster overlay textures, in either direction.
Represents an HTML string that should be shown on screen to attribute third parties for used data,...
