CesiumAsync::IAssetAccessor Class Referenceabstract
Provides asynchronous access to assets, usually files downloaded via HTTP. More...
#include <CesiumAsync/IAssetAccessor.h>
Inheritance diagram for CesiumAsync::IAssetAccessor:
CesiumAsync::CachingAssetAccessor CesiumAsync::CesiumIonAssetAccessor CesiumAsync::GunzipAssetAccessor CesiumCurl::CurlAssetAccessor
Public Types
typedef std::pair< std::string, std::string > THeader
 An HTTP header represented as a key/value pair.
virtual CesiumAsync::Future< std::shared_ptr< IAssetRequest > > get (const AsyncSystem &asyncSystem, const std::string &url, const std::vector< THeader > &headers={})=0
 Starts a new request for the asset with the given URL. The request proceeds asynchronously without blocking the calling thread.
virtual CesiumAsync::Future< std::shared_ptr< IAssetRequest > > request (const AsyncSystem &asyncSystem, const std::string &verb, const std::string &url, const std::vector< THeader > &headers=std::vector< THeader >(), const std::span< const std::byte > &contentPayload={})=0
 Starts a new request to the given URL, using the provided HTTP verb and the provided content payload.
virtual void tick () noexcept=0
 Ticks the asset accessor system while the main thread is blocked.
Definition at line 21 of file IAssetAccessor.h.
Member Typedef Documentation
◆ THeader
typedef std::pair<std::string, std::string> CesiumAsync::IAssetAccessor::THeader
Definition at line 26 of file IAssetAccessor.h.
◆ get()
virtual CesiumAsync::Future< std::shared_ptr< IAssetRequest > > CesiumAsync::IAssetAccessor::get ( const AsyncSystem & asyncSystem,
const std::string & url,
const std::vector< THeader > & headers = {} )
pure virtual
asyncSystemThe async system used to do work in threads.
urlThe URL of the asset.
headersThe headers to include in the request.
The in-progress asset request.
Implemented in CesiumAsync::CachingAssetAccessor, CesiumAsync::CesiumIonAssetAccessor, CesiumAsync::GunzipAssetAccessor, and CesiumCurl::CurlAssetAccessor.
◆ request()
virtual CesiumAsync::Future< std::shared_ptr< IAssetRequest > > CesiumAsync::IAssetAccessor::request ( const AsyncSystem & asyncSystem,
const std::string & verb,
const std::vector< THeader > & headers = std::vector< THeader >(),
const std::span< const std::byte > & contentPayload = {} )
pure virtual
verbThe HTTP verb to use, such as "POST" or "PATCH".
contentPayloadThe payload data to include in the request.
◆ tick()
virtual void CesiumAsync::IAssetAccessor::tick ( )
pure virtualnoexcept
If the asset accessor is not dependent on the main thread to dispatch requests, this method does not need to do anything.
