CesiumRasterOverlays::DebugColorizeTilesRasterOverlay Class Reference
A raster overlay that gives each tile to which it is attached a random color with 50% opacity. This is useful for debugging a tileset, to visualize how it is divided into tiles. More...
#include <CesiumRasterOverlays/DebugColorizeTilesRasterOverlay.h>
Inheritance diagram for CesiumRasterOverlays::DebugColorizeTilesRasterOverlay:
CesiumRasterOverlays::RasterOverlay CesiumUtility::ReferenceCounted< T, false >
 DebugColorizeTilesRasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
 Creates a new instance.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider (const CreateRasterOverlayTileProviderParameters &parameters) const override
 Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future.
- Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem)
 A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
const std::string & getName () const noexcept
 Gets the name of this overlay.
RasterOverlayOptions & getOptions () noexcept
 Gets options for this overlay.
const RasterOverlayOptions & getOptions () const noexcept
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Activates this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously.
void addReference () const
Additional Inherited Members
- Public Types inherited from CesiumRasterOverlays::RasterOverlay
using CreateTileProviderResult
 A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful.
Definition at line 13 of file DebugColorizeTilesRasterOverlay.h.
◆ DebugColorizeTilesRasterOverlay()
CesiumRasterOverlays::DebugColorizeTilesRasterOverlay::DebugColorizeTilesRasterOverlay ( const std::string & name,
const RasterOverlayOptions & overlayOptions = RasterOverlayOptions() )
nameThe user-given name of this overlay layer.
overlayOptionsThe RasterOverlayOptions for this instance.
◆ createTileProvider()
virtual CesiumAsync::Future< CreateTileProviderResult > CesiumRasterOverlays::DebugColorizeTilesRasterOverlay::createTileProvider ( const CreateRasterOverlayTileProviderParameters & parameters) const
overridevirtual
parametersThe parameters for creating the tile provider.
The future that resolves to the tile provider when it is ready, or to error details in the case of an error.
Implements CesiumRasterOverlays::RasterOverlay.
