CesiumRasterOverlays::UrlTemplateRasterOverlay Class Referencefinal
A RasterOverlay accessing images from a templated URL. More...
#include <CesiumRasterOverlays/UrlTemplateRasterOverlay.h>
Inheritance diagram for CesiumRasterOverlays::UrlTemplateRasterOverlay:
CesiumRasterOverlays::RasterOverlay CesiumUtility::ReferenceCounted< T, false >
 UrlTemplateRasterOverlay (const std::string &name, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers={}, const UrlTemplateRasterOverlayOptions &urlTemplateOptions={}, const RasterOverlayOptions &overlayOptions={})
 Creates a new instance.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider (const CreateRasterOverlayTileProviderParameters &parameters) const override
 Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future.
- Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay
 RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem)
 A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
const std::string & getName () const noexcept
 Gets the name of this overlay.
RasterOverlayOptions & getOptions () noexcept
 Gets options for this overlay.
const RasterOverlayOptions & getOptions () const noexcept
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Activates this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously.
void addReference () const
Additional Inherited Members
- Public Types inherited from CesiumRasterOverlays::RasterOverlay
using CreateTileProviderResult
 A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful.
Definition at line 79 of file UrlTemplateRasterOverlay.h.
◆ UrlTemplateRasterOverlay()
CesiumRasterOverlays::UrlTemplateRasterOverlay::UrlTemplateRasterOverlay ( const std::string & name,
const std::string & url,
const std::vector< CesiumAsync::IAssetAccessor::THeader > & headers = {},
const UrlTemplateRasterOverlayOptions & urlTemplateOptions = {},
const RasterOverlayOptions & overlayOptions = {} )
The following template parameters are supported in url:
  • {x} - The tile X coordinate in the tiling scheme, where 0 is the westernmost tile.
  • {y} - The tile Y coordinate in the tiling scheme, where 0 is the southernmost tile.
  • {z} - The level of the tile in the tiling scheme, where 0 is the root of the quadtree pyramid.
  • {reverseX} - The tile X coordinate in the tiling scheme, where 0 is the easternmost tile.
  • {reverseY} - The tile Y coordinate in the tiling scheme, where 0 is the northernmost tile.
  • {reverseZ} - The tile Z coordinate in the tiling scheme, where 0 is equivalent to urlTemplateOptions.maximumLevel.
  • {westDegrees} - The western edge of the tile in geodetic degrees.
  • {southDegrees} - The southern edge of the tile in geodetic degrees.
  • {eastDegrees} - The eastern edge of the tile in geodetic degrees.
  • {northDegrees} - The northern edge of the tile in geodetic degrees.
  • {minimumX} - The minimum X coordinate of the tile's projected coordinates.
  • {minimumY} - The minimum Y coordinate of the tile's projected coordinates.
  • {maximumX} - The maximum X coordinate of the tile's projected coordinates.
  • {maximumY} - The maximum Y coordinate of the tile's projected coordinates.
  • {width} - The width of each tile in pixels.
  • {height} - The height of each tile in pixels.
nameThe user-given name of this overlay layer.
urlThe URL with template parameters.
headersThe headers. This is a list of pairs of strings of the form (Key,Value) that will be inserted as request headers internally.
urlTemplateOptionsThe UrlTemplateRasterOverlayOptions.
overlayOptionsThe RasterOverlayOptions for this instance.
Definition at line 110 of file UrlTemplateRasterOverlay.h.
◆ createTileProvider()
virtual CesiumAsync::Future< CreateTileProviderResult > CesiumRasterOverlays::UrlTemplateRasterOverlay::createTileProvider ( const CreateRasterOverlayTileProviderParameters & parameters) const
overridevirtual
parametersThe parameters for creating the tile provider.
The future that resolves to the tile provider when it is ready, or to error details in the case of an error.
Implements CesiumRasterOverlays::RasterOverlay.
