CesiumRasterOverlays::IPrepareRasterOverlayRendererResources Class Referenceabstract
An interface between Cesium Native and the application using it, allowing Cesium Native to pass loaded raster overlay data to the implementing application in order for the application to prepare it to be used in its renderer of choice. This could involve creating a texture asset, uploading the texture data to the GPU, or any other similar tasks required. More...
#include <CesiumRasterOverlays/IPrepareRasterOverlayRendererResources.h>
Inheritance diagram for CesiumRasterOverlays::IPrepareRasterOverlayRendererResources:
Cesium3DTilesSelection::IPrepareRendererResources
virtual void * prepareRasterInLoadThread (CesiumImage::ImageAsset &image, const std::any &rendererOptions)=0
 Prepares a raster overlay tile.
virtual void * prepareRasterInMainThread (RasterOverlayTile &rasterTile, void *pLoadThreadResult)=0
 Further preprares a raster overlay tile.
virtual void freeRaster (const RasterOverlayTile &rasterTile, void *pLoadThreadResult, void *pMainThreadResult) noexcept=0
 Frees previously-prepared renderer resources for a raster tile.
Definition at line 24 of file IPrepareRasterOverlayRendererResources.h.
◆ freeRaster()
virtual void CesiumRasterOverlays::IPrepareRasterOverlayRendererResources::freeRaster ( const RasterOverlayTile & rasterTile,
void * pLoadThreadResult,
void * pMainThreadResult )
pure virtualnoexcept
This method is always called from the thread that destroyed the RasterOverlayTile. When raster overlays are used with tilesets, this is the thread that called Cesium3DTilesSelection::Tileset::updateView or deleted the tileset.
rasterTileThe tile for which to free renderer resources.
pLoadThreadResultThe result returned by prepareRasterInLoadThread. If prepareRasterInMainThread has already been called, this parameter will be nullptr.
pMainThreadResultThe result returned by prepareRasterInMainThread. If prepareRasterInMainThread has not yet been called, this parameter will be nullptr.
◆ prepareRasterInLoadThread()
virtual void * CesiumRasterOverlays::IPrepareRasterOverlayRendererResources::prepareRasterInLoadThread ( CesiumImage::ImageAsset & image,
const std::any & rendererOptions )
pure virtual
This method is invoked in the load thread and may modify the image.
imageThe raster tile image to prepare.
rendererOptionsRenderer options associated with the raster overlay tile from RasterOverlayOptions::rendererOptions.
Arbitrary data representing the result of the load process. This data is passed to prepareRasterInMainThread as the pLoadThreadResult parameter.
◆ prepareRasterInMainThread()
virtual void * CesiumRasterOverlays::IPrepareRasterOverlayRendererResources::prepareRasterInMainThread ( RasterOverlayTile & rasterTile,
void * pLoadThreadResult )
pure virtual
This is called after prepareRasterInLoadThread, and unlike that method, this one is called from the same thread that called Cesium3DTilesSelection::Tileset::updateView.
rasterTileThe raster tile to prepare.
pLoadThreadResultThe value returned from prepareRasterInLoadThread.
Arbitrary data representing the result of the load process. Note that the value returned by prepareRasterInLoadThread will not be automatically preserved and passed to freeRaster. If you need to free that value, do it in this method before returning. If you need that value later, add it to the object returned from this method.
