CesiumGeospatial Namespace Reference
Classes for geospatial computations in Cesium. More...
Classes
class  BoundingRegion
 A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height. More...
class  BoundingRegionBuilder
 Helper class for creating a BoundingRegion or GlobeRectangle from a set of points. More...
class  BoundingRegionWithLooseFittingHeights
 A BoundingRegion whose heights might be very inaccurate and so distances should be estimated conservatively for level-of-detail computations. More...
class  Cartographic
 A position defined by longitude, latitude, and height. More...
class  CartographicPolygon
 A 2D polygon expressed as a list of longitude/latitude coordinates in radians. More...
class  EarthGravitationalModel1996Grid
 Loads and queries heights from an Earth Gravitational Model 1996 (EGM96) grid. More...
class  Ellipsoid
 A quadratic surface defined in Cartesian coordinates. More...
class  EllipsoidTangentPlane
 A plane tangent to an Ellipsoid at a certain origin position. More...
class  GeographicProjection
 A map projection where longitude and latitude are mapped using an Ellipsoid. More...
class  GlobeAnchor
 Anchors an object to the globe by defining a transformation from the object's coordinate to the globe-fixed coordinate system (usually Earth-Centered, Earth-Fixed Coordinates (ECEF)). More...
class  GlobeRectangle
 A two-dimensional, rectangular region on a globe, specified using longitude and latitude coordinates. The region is rectangular in terms of longitude-latitude coordinates, but may be far from rectangular on the actual globe surface. More...
class  GlobeTransforms
 Transforms between globe-related coordinate systems. More...
class  LocalHorizontalCoordinateSystem
 A coordinate system created from a local horizontal plane at a particular origin point on the globe. More...
class  S2CellBoundingVolume
class  S2CellID
 A 64-bit unsigned integer that uniquely identifies a cell in the S2 cell decomposition. More...
class  SimplePlanarEllipsoidCurve
 Produces points on an ellipse that lies on a plane that intersects the center of the earth and each of the input coordinates. The height above the surface at each point along the curve will be a linear interpolation between the source and destination heights. More...
class  WebMercatorProjection
 The map projection used by Google Maps, Bing Maps, and most of ArcGIS Online, EPSG:3857. More...
Typedefs
typedef std::variant< GeographicProjection, WebMercatorProjection > Projection
 A projection.
Enumerations
enum class  LocalDirection {
  East , North , West , South ,
  Up , Down
 A local direction, consisting of the four cardinal directions (North, South, East, West) combined with Up and Down. More...
Functions
double calcQuadtreeMaxGeometricError (const CesiumGeospatial::Ellipsoid &ellipsoid) noexcept
 Computes the maximum geometric error per radian of a quadtree with certain assumptions.
glm::dvec3 projectPosition (const Projection &projection, const Cartographic &position)
 Projects a position on the globe using the given Projection.
Cartographic unprojectPosition (const Projection &projection, const glm::dvec3 &position)
 Unprojects a position from the globe using the given Projection.
CesiumGeometry::Rectangle projectRectangleSimple (const Projection &projection, const GlobeRectangle &rectangle)
 Projects a rectangle on the globe by simply projecting its four corners.
GlobeRectangle unprojectRectangleSimple (const Projection &projection, const CesiumGeometry::Rectangle &rectangle)
 Unprojects a rectangle to the globe by simply unprojecting its four corners.
CesiumGeometry::AxisAlignedBox projectRegionSimple (const Projection &projection, const BoundingRegion &region)
 Projects a bounding region on the globe by simply projecting its eight corners.
BoundingRegion unprojectRegionSimple (const Projection &projection, const CesiumGeometry::AxisAlignedBox &box, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Unprojects a box to the globe by simply unprojecting its eight corners.
glm::dvec2 computeProjectedRectangleSize (const Projection &projection, const CesiumGeometry::Rectangle &rectangle, double maxHeight, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Computes the approximate real-world size, in meters, of a given projected rectangle.
const Ellipsoid & getProjectionEllipsoid (const Projection &projection)
 Obtains the ellipsoid used by a Projection variant.
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: CesiumGeospatial Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px CesiumGeospatial[CesiumGeospatial] --> CesiumGeometry[CesiumGeometry] CesiumGeospatial[CesiumGeospatial] --> CesiumUtility[CesiumUtility] CesiumGeospatial[CesiumGeospatial] --> earcut{{earcut}} CesiumGeospatial[CesiumGeospatial] --> s2_s2{{s2::s2}} class earcut,s2_s2 dependencyNode class CesiumGeometry,CesiumUtility,CesiumGeospatial libraryNode
Typedef Documentation
◆ Projection
A projection.
This is a std::variant of different types of map projections that can convert between projected map coordinates and Cartographic coordinates.
See also
Definition at line 25 of file Projection.h.
◆ LocalDirection
Definition at line 19 of file LocalHorizontalCoordinateSystem.h.
Function Documentation
◆ calcQuadtreeMaxGeometricError()
double CesiumGeospatial::calcQuadtreeMaxGeometricError ( const CesiumGeospatial::Ellipsoid & ellipsoid)
noexcept
The geometric error for a tile can be computed by multiplying the value returned by this function by the width of the tile in radians.
This function computes a suitable geometric error for a 65x65 terrain heightmap where the vertical error is 25% of the horizontal spacing between height samples at the equator.
ellipsoidThe ellipsoid.
The max geometric error.
◆ computeProjectedRectangleSize()
glm::dvec2 CesiumGeospatial::computeProjectedRectangleSize ( const Projection & projection,
const CesiumGeometry::Rectangle & rectangle,
double maxHeight,
const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 )
The returned X component corresponds to the size in the projected X direction, while the returned Y component corresponds to the size in the projected Y direction.
projectionThe projection.
rectangleThe projected rectangle to measure.
maxHeightThe maximum height of the geometry inside the rectangle.
ellipsoidThe ellipsoid used to convert longitude and latitude to ellipsoid-centered coordinates.
The approximate size.
◆ projectPosition()
glm::dvec3 CesiumGeospatial::projectPosition ( const Projection & projection,
const Cartographic & position )
positionThe Cartographic position.
The coordinates of the projected point, in the coordinate system of the given projection.
◆ projectRectangleSimple()
CesiumGeometry::Rectangle CesiumGeospatial::projectRectangleSimple ( const Projection & projection,
const GlobeRectangle & rectangle )
This is only accurate when the globe rectangle is still a rectangle after projecting, which is true for WebMercatorProjection but not necessarily true for other projections.
rectangleThe globe rectangle to be projected.
The projected rectangle.
◆ projectRegionSimple()
CesiumGeometry::AxisAlignedBox CesiumGeospatial::projectRegionSimple ( const Projection & projection,
const BoundingRegion & region )
This is only accurate when the globe box is still a box after projecting, which is true for WebMercatorProjection but not necessarily true for other projections.
regionThe bounding region to be projected.
The projected box.
◆ unprojectPosition()
Cartographic CesiumGeospatial::unprojectPosition ( const Projection & projection,
const glm::dvec3 & position )
positionThe coordinates of the point, in meters.
◆ unprojectRectangleSimple()
GlobeRectangle CesiumGeospatial::unprojectRectangleSimple ( const Projection & projection,
const CesiumGeometry::Rectangle & rectangle )
This is only accurate when the rectangle is still a rectangle after unprojecting, which is true for WebMercatorProjection but not necessarily true for other projections.
rectangleThe rectangle to be unprojected.
The unprojected rectangle.
◆ unprojectRegionSimple()
BoundingRegion CesiumGeospatial::unprojectRegionSimple ( const Projection & projection,
const CesiumGeometry::AxisAlignedBox & box,
This is only accurate when the box is still a box after unprojecting, which is true for WebMercatorProjection but not necessarily true for other projections.
boxThe box to be unprojected.
The unprojected bounding region.
