CesiumGeospatial::EarthGravitationalModel1996Grid Class Referencefinal
Loads and queries heights from an Earth Gravitational Model 1996 (EGM96) grid. More...
#include <CesiumGeospatial/EarthGravitationalModel1996Grid.h>
double sampleHeight (const Cartographic &position) const
 Samples the height at the given position.
static std::optional< EarthGravitationalModel1996Grid > fromBuffer (const std::span< const std::byte > &buffer)
 Attempts to create a EarthGravitationalModel1996Grid from the given buffer.
EGM96 is a standard geopotential model of the earth's surface, which can be used to obtain an approximation of the mean sea level (MSL) height at any location on Earth.
Definition at line 23 of file EarthGravitationalModel1996Grid.h.
◆ fromBuffer()
static std::optional< EarthGravitationalModel1996Grid > CesiumGeospatial::EarthGravitationalModel1996Grid::fromBuffer ( const std::span< const std::byte > & buffer)
static
This method expects the buffer to contain the contents of the WW15MGH.DAC 15-arcminute grid. It must be at least 721 * 1440 * 2 = 2,076,480 bytes. Any additional bytes at the end of the buffer are ignored.
The instance created from the buffer, or std::nullopt if the buffer cannot be interpreted as an EGM96 grid.
◆ sampleHeight()
double CesiumGeospatial::EarthGravitationalModel1996Grid::sampleHeight ( const Cartographic & position) const
positionThe position to sample. The height is ignored.
The height (in meters) of the EGM96 surface above the WGS84 ellipsoid. A positive value indicates that EGM96 is above the ellipsoid's surface, while a negative value indicates that EGM96 is below the ellipsoid's surface.
