CesiumGeospatial::CartographicPolygon Class Referencefinal
A 2D polygon expressed as a list of longitude/latitude coordinates in radians. More...
#include <CesiumGeospatial/CartographicPolygon.h>
 CartographicPolygon (const std::vector< glm::dvec2 > &polygon)
 Constructs a 2D polygon that can be rasterized onto Cesium3DTilesSelection::Tileset objects.
constexpr const std::vector< glm::dvec2 > & getVertices () const
 Returns the longitude-latitude vertices that define the perimeter of the selected polygon.
constexpr const std::vector< uint32_t > & getIndices () const
 Returns the triangulated indices representing a triangle decomposition of the polygon. The indices are in reference to the polygon's perimeter vertices.
constexpr const std::optional< CesiumGeospatial::GlobeRectangle > & getBoundingRectangle () const
 Returns a GlobeRectangle that represents the bounding rectangle of the polygon.
static bool rectangleIsWithinPolygons (const CesiumGeospatial::GlobeRectangle &rectangle, const std::vector< CesiumGeospatial::CartographicPolygon > &cartographicPolygons) noexcept
 Determines whether a globe rectangle is completely inside any of the polygons in a list.
static bool rectangleIsOutsidePolygons (const CesiumGeospatial::GlobeRectangle &rectangle, const std::vector< CesiumGeospatial::CartographicPolygon > &cartographicPolygons) noexcept
 Determines whether a globe rectangle is completely outside all the polygons in a list.
The Ellipsoid associated with the coordinates is not specified directly by this instance, but it is assumed that the longitude values range from -PI to PI radians and the latitude values range from -PI/2 to PI/2 radians. Longitude values outside this range are wrapped to be inside the range. Latitude values are clamped to the range.
Definition at line 24 of file CartographicPolygon.h.
◆ CartographicPolygon()
CesiumGeospatial::CartographicPolygon::CartographicPolygon ( const std::vector< glm::dvec2 > & polygon)
polygonAn array of longitude-latitude points in radians defining the perimeter of the 2D polygon.
◆ getBoundingRectangle()
const std::optional< CesiumGeospatial::GlobeRectangle > & CesiumGeospatial::CartographicPolygon::getBoundingRectangle ( ) const
inlineconstexpr
The polygon's global bounding rectangle.
Definition at line 63 of file CartographicPolygon.h.
◆ getIndices()
const std::vector< uint32_t > & CesiumGeospatial::CartographicPolygon::getIndices ( ) const
inlineconstexpr
The indices for the polygon's triangle decomposition.
Definition at line 52 of file CartographicPolygon.h.
◆ getVertices()
const std::vector< glm::dvec2 > & CesiumGeospatial::CartographicPolygon::getVertices ( ) const
inlineconstexpr
The perimeter vertices in longitude-latitude radians.
Definition at line 41 of file CartographicPolygon.h.
◆ rectangleIsOutsidePolygons()
static bool CesiumGeospatial::CartographicPolygon::rectangleIsOutsidePolygons ( const CesiumGeospatial::GlobeRectangle & rectangle,
const std::vector< CesiumGeospatial::CartographicPolygon > & cartographicPolygons )
staticnoexcept
rectangleThe CesiumGeospatial::GlobeRectangle of the tile.
cartographicPolygonsThe list of polygons to check.
True if the rectangle is completely outside all the polygons; otherwise, false.
◆ rectangleIsWithinPolygons()
static bool CesiumGeospatial::CartographicPolygon::rectangleIsWithinPolygons ( const CesiumGeospatial::GlobeRectangle & rectangle,
staticnoexcept
True if the rectangle is completely inside a polygon; otherwise, false.
