Transforms between globe-related coordinate systems. More...
#include <CesiumGeospatial/GlobeTransforms.h>
| static glm::dmat4x4 | eastNorthUpToFixedFrame (const glm::dvec3 &origin, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept |
| Computes a transformation from east-north-up axes to an ellipsoid-fixed reference frame. | |
Definition at line 14 of file GlobeTransforms.h.
staticnoexcept |
Computes a 4x4 transformation matrix from a reference frame with an east-north-up axes centered at the provided origin to the provided ellipsoid's fixed reference frame. The local axes are defined as:
x axis points in the local east direction. y axis points in the local north direction. z axis points in the direction of the ellipsoid surface normal which passes through the position. | origin | The center point of the local reference frame. |
| ellipsoid | The Ellipsoid whose fixed frame is used in the transformation. Default value: Ellipsoid::WGS84. |
