CesiumGeospatial::GeographicProjection Class Referencefinal
A map projection where longitude and latitude are mapped using an Ellipsoid. More...
#include <CesiumGeospatial/GeographicProjection.h>
 GeographicProjection (const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
const Ellipsoid & getEllipsoid () const noexcept
 Gets the Ellipsoid.
glm::dvec3 project (const Cartographic &cartographic) const noexcept
 Converts geodedic ellipsoid coordinates to geographic coordinates.
CesiumGeometry::Rectangle project (const CesiumGeospatial::GlobeRectangle &rectangle) const noexcept
 Projects a globe rectangle to geographic coordinates.
Cartographic unproject (const glm::dvec2 &projectedCoordinates) const noexcept
 Converts geographic coordinates to geodetic ellipsoid coordinates.
Cartographic unproject (const glm::dvec3 &projectedCoordinates) const noexcept
CesiumGeospatial::GlobeRectangle unproject (const CesiumGeometry::Rectangle &rectangle) const noexcept
 Unprojects a geographic rectangle to the globe.
bool operator== (const GeographicProjection &rhs) const noexcept
 Returns true if two projections (i.e. their ellipsoids) are equal.
bool operator!= (const GeographicProjection &rhs) const noexcept
 Returns true if two projections (i.e. their ellipsoids) are not equal.
static constexpr CesiumGeometry::Rectangle computeMaximumProjectedRectangle (const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
 Computes the maximum rectangle that can be covered with this projection.
static constexpr GlobeRectangle MAXIMUM_GLOBE_RECTANGLE
 The maximum bounding rectangle of the geographic projection, ranging from -PI to PI radians longitude and from -PI/2 to +PI/2 radians latitude.
The longitude and latitude are linearly mapped to X and Y by multiplying them (in radians) by the Ellipsoid::getMaximumRadius(). This projection is commonly known as geographic, equirectangular, equidistant cylindrical, or plate carrée. It is also known as EPSG:4326.
See also
WebMercatorProjection
Definition at line 26 of file GeographicProjection.h.
◆ GeographicProjection()
CesiumGeospatial::GeographicProjection::GeographicProjection ( const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84)
noexcept
ellipsoidThe Ellipsoid.
◆ computeMaximumProjectedRectangle()
static constexpr CesiumGeometry::Rectangle CesiumGeospatial::GeographicProjection::computeMaximumProjectedRectangle ( const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84)
inlinestaticconstexprnoexcept
ellipsoidThe Ellipsoid. Default value: Ellipsoid::WGS84.
The rectangle
Definition at line 47 of file GeographicProjection.h.
◆ getEllipsoid()
const Ellipsoid & CesiumGeospatial::GeographicProjection::getEllipsoid ( ) const
inlinenoexcept
Gets the Ellipsoid.
Definition at line 71 of file GeographicProjection.h.
◆ operator!=()
bool CesiumGeospatial::GeographicProjection::operator!= ( const GeographicProjection & rhs) const
inlinenoexcept
Definition at line 144 of file GeographicProjection.h.
◆ operator==()
bool CesiumGeospatial::GeographicProjection::operator== ( const GeographicProjection & rhs) const
inlinenoexcept
Definition at line 136 of file GeographicProjection.h.
◆ project() [1/2]
glm::dvec3 CesiumGeospatial::GeographicProjection::project ( const Cartographic & cartographic) const
noexcept
Converts geodetic ellipsoid coordinates, in radians, to the equivalent geographic X, Y, Z coordinates expressed in meters. The height is copied unmodified to the z coordinate.
cartographicThe geodetic coordinates in radians.
The equivalent geographic X, Y, Z coordinates, in meters.
◆ project() [2/2]
CesiumGeometry::Rectangle CesiumGeospatial::GeographicProjection::project ( const CesiumGeospatial::GlobeRectangle & rectangle) const
noexcept
This is done by projecting the southwest and northeast corners.
rectangleThe globe rectangle to project.
The projected rectangle.
◆ unproject() [1/3]
CesiumGeospatial::GlobeRectangle CesiumGeospatial::GeographicProjection::unproject ( const CesiumGeometry::Rectangle & rectangle) const
noexcept
This is done by unprojecting the southwest and northeast corners.
rectangleThe rectangle to unproject.
The unprojected rectangle.
◆ unproject() [2/3]
Cartographic CesiumGeospatial::GeographicProjection::unproject ( const glm::dvec2 & projectedCoordinates) const
noexcept
Converts geographic X and Y coordinates, expressed in meters, to a Cartographic containing geodetic ellipsoid coordinates. The height is set to 0.0.
projectedCoordinatesThe geographic projected coordinates to unproject.
The equivalent cartographic coordinates.
◆ unproject() [3/3]
Cartographic CesiumGeospatial::GeographicProjection::unproject ( const glm::dvec3 & projectedCoordinates) const
noexcept
Converts geographic X, Y coordinates, expressed in meters, to a Cartographic containing geodetic ellipsoid coordinates. The Z coordinate is copied unmodified to the height.
projectedCoordinatesThe geographic projected coordinates to unproject, with height (z) in meters.
◆ MAXIMUM_GLOBE_RECTANGLE
GlobeRectangle CesiumGeospatial::GeographicProjection::MAXIMUM_GLOBE_RECTANGLE
Initial value:
A two-dimensional, rectangular region on a globe, specified using longitude and latitude coordinates....
static constexpr double PiOverTwo
Pi divided by two.
Definition Math.h:91
static constexpr double OnePi
Pi.
Definition Math.h:81
Definition at line 33 of file GeographicProjection.h.
