An Axis-Aligned Bounding Box (AABB), where the axes of the box are aligned with the axes of the coordinate system. More...
#include <CesiumGeometry/AxisAlignedBox.h>
| constexpr | AxisAlignedBox () noexcept |
| Creates an empty AABB with a length, width, and height of zero, with the center located at (0, 0, 0). | |
| constexpr | AxisAlignedBox (double minimumX_, double minimumY_, double minimumZ_, double maximumX_, double maximumY_, double maximumZ_) noexcept |
| Creates a new AABB using the range of coordinates the box covers. | |
| constexpr bool | contains (const glm::dvec3 &position) const noexcept |
| Checks if this AABB contains the given position. | |
| static AxisAlignedBox | fromPositions (const std::vector< glm::dvec3 > &positions) |
| Creates a tight-fitting, axis-aligned bounding box that contains all of the input positions. | |
| double | minimumX |
| The minimum x-coordinate. | |
| double | minimumY |
| The minimum y-coordinate. | |
| double | minimumZ |
| The minimum z-coordinate. | |
| double | maximumX |
| The maximum x-coordinate. | |
| double | maximumY |
| The maximum y-coordinate. | |
| double | maximumZ |
| The maximum z-coordinate. | |
| double | lengthX |
| The length of the box on the x-axis. | |
| double | lengthY |
| The length of the box on the y-axis. | |
| double | lengthZ |
| The length of the box on the z-axis. | |
| glm::dvec3 | center |
| The center of the box. | |
Definition at line 16 of file AxisAlignedBox.h.
inlineconstexprnoexcept |
Definition at line 22 of file AxisAlignedBox.h.
| minimumX_ | The minimum X coordinate within the box. |
| minimumY_ | The minimum Y coordinate within the box. |
| minimumZ_ | The minimum Z coordinate within the box. |
| maximumX_ | The maximum X coordinate within the box. |
| maximumY_ | The maximum Y coordinate within the box. |
| maximumZ_ | The maximum Z coordinate within the box. |
Definition at line 44 of file AxisAlignedBox.h.
| position | The position to check. |
Definition at line 121 of file AxisAlignedBox.h.
static |
| positions | The positions. |
| glm::dvec3 CesiumGeometry::AxisAlignedBox::center |
Definition at line 113 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::lengthX |
Definition at line 98 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::lengthY |
Definition at line 103 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::lengthZ |
Definition at line 108 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::maximumX |
Definition at line 83 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::maximumY |
Definition at line 88 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::maximumZ |
Definition at line 93 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::minimumX |
Definition at line 68 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::minimumY |
Definition at line 73 of file AxisAlignedBox.h.
| double CesiumGeometry::AxisAlignedBox::minimumZ |
Definition at line 78 of file AxisAlignedBox.h.
