Helper class for creating a BoundingRegion or GlobeRectangle from a set of points. More...
#include <CesiumGeospatial/BoundingRegionBuilder.h>
| BoundingRegionBuilder () noexcept | |
| Constructs a new instance, starting with an empty bounding region. | |
| BoundingRegion | toRegion (const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const |
| Gets the final region from this builder. | |
| GlobeRectangle | toGlobeRectangle () const |
| Gets the final globe rectangle from this builder. | |
| void | setPoleTolerance (double tolerance) noexcept |
| Sets the distance from the North or South pole, in radians, that is considered "too close" to rely on the longitude value. | |
| double | getPoleTolerance () const noexcept |
| Gets the distance from the North or South pole, in radians, that is considered "too close" to rely on the longitude value. | |
| bool | expandToIncludePosition (const Cartographic &position) |
| Expands the bounding region to include the given position. | |
| bool | expandToIncludeGlobeRectangle (const GlobeRectangle &rectangle) |
| Expands the bounding region to include the given globe rectangle. | |
| bool | expandToIncludeBoundingRegion (const BoundingRegion ®ion) |
| Expands the bounding region to include the given bounding region. | |
Definition at line 13 of file BoundingRegionBuilder.h.
| bool CesiumGeospatial::BoundingRegionBuilder::expandToIncludeBoundingRegion | ( | const BoundingRegion & | region | ) |
The region will be kept as small as possible.
| region | The region to be included in the region. |
| bool CesiumGeospatial::BoundingRegionBuilder::expandToIncludeGlobeRectangle | ( | const GlobeRectangle & | rectangle | ) |
| rectangle | The rectangle to be included in the region. |
| bool CesiumGeospatial::BoundingRegionBuilder::expandToIncludePosition | ( | const Cartographic & | position | ) |
| position | The position to be included in the region. |
noexcept |
When a position given to expandToIncludePosition has a latitude closer than this value, the region will be updated to include the position's latitude, but the position's longitude will be ignored.
noexcept |
| tolerance | The new tolerance. |
| GlobeRectangle CesiumGeospatial::BoundingRegionBuilder::toGlobeRectangle | ( | ) | const |
If no positions are added to this builder, the returned region's rectangle will be GlobeRectangle::EMPTY.
| BoundingRegion CesiumGeospatial::BoundingRegionBuilder::toRegion | ( | const Ellipsoid & | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 | ) | const |
If no positions are added to this builder, the returned region's rectangle will be GlobeRectangle::EMPTY, its minimum height will be 1.0, and its maximum height will be -1.0 (the minimum will be greater than the maximum).
