A plane tangent to an Ellipsoid at a certain origin position. More...
#include <CesiumGeospatial/EllipsoidTangentPlane.h>
| EllipsoidTangentPlane (const glm::dvec3 &origin, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new instance. | |
| EllipsoidTangentPlane (const glm::dmat4 &eastNorthUpToFixedFrame, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| const Ellipsoid & | getEllipsoid () const noexcept |
| Returns the Ellipsoid. | |
| const glm::dvec3 & | getOrigin () const noexcept |
| Returns the origin, in cartesian coordinates. | |
| const glm::dvec3 & | getXAxis () const noexcept |
| Returns the x-axis of this plane. | |
| const glm::dvec3 & | getYAxis () const noexcept |
| Returns the y-axis of this plane. | |
| const glm::dvec3 & | getZAxis () const noexcept |
| Returns the z-axis (i.e. the normal) of this plane. | |
| const CesiumGeometry::Plane & | getPlane () const noexcept |
| Returns a CesiumGeometry::Plane representation of this plane. | |
| glm::dvec2 | projectPointToNearestOnPlane (const glm::dvec3 &cartesian) const noexcept |
| Computes the position of the projection of the given point on this plane. | |
If the origin is not on the surface of the ellipsoid, its surface projection will be used.
Definition at line 19 of file EllipsoidTangentPlane.h.
| CesiumGeospatial::EllipsoidTangentPlane::EllipsoidTangentPlane | ( | const glm::dvec3 & | origin, |
| const Ellipsoid & | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) |
| origin | The origin, in cartesian coordinates. |
| ellipsoid | The ellipsoid. Default value: Ellipsoid::WGS84. |
| An | std::invalid_argument if the given origin is at the center of the ellipsoid. |
| CesiumGeospatial::EllipsoidTangentPlane::EllipsoidTangentPlane | ( | const glm::dmat4 & | eastNorthUpToFixedFrame, |
| eastNorthUpToFixedFrame | A transform that was computed with GlobeTransforms::eastNorthUpToFixedFrame. |
inlinenoexcept |
Definition at line 47 of file EllipsoidTangentPlane.h.
inlinenoexcept |
Definition at line 52 of file EllipsoidTangentPlane.h.
inlinenoexcept |
Definition at line 75 of file EllipsoidTangentPlane.h.
inlinenoexcept |
Definition at line 57 of file EllipsoidTangentPlane.h.
inlinenoexcept |
Definition at line 62 of file EllipsoidTangentPlane.h.
inlinenoexcept |
Definition at line 67 of file EllipsoidTangentPlane.h.
noexcept |
Projects the given point on this plane, along the normal. The result will be a 2D point, referring to the local coordinate system of the plane that is given by the x- and y-axis.
| cartesian | The point in cartesian coordinates. |
