CesiumGeospatial::LocalHorizontalCoordinateSystem Class Reference
A coordinate system created from a local horizontal plane at a particular origin point on the globe. More...
#include <CesiumGeospatial/LocalHorizontalCoordinateSystem.h>
 LocalHorizontalCoordinateSystem (const Cartographic &origin, LocalDirection xAxisDirection=LocalDirection::East, LocalDirection yAxisDirection=LocalDirection::North, LocalDirection zAxisDirection=LocalDirection::Up, double scaleToMeters=1.0, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Create a new coordinate system centered at a given longitude, latitude, and ellipsoidal height.
 LocalHorizontalCoordinateSystem (const glm::dvec3 &originEcef, LocalDirection xAxisDirection=LocalDirection::East, LocalDirection yAxisDirection=LocalDirection::North, LocalDirection zAxisDirection=LocalDirection::Up, double scaleToMeters=1.0, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Create a new coordinate system centered at a Earth-Centered, Earth-Fixed position.
 LocalHorizontalCoordinateSystem (const glm::dmat4 &localToEcef)
 Create a new coordinate system with a specified transformation to the Earth-Centered, Earth-Fixed frame. This is an advanced constructor and should be avoided in most cases.
 LocalHorizontalCoordinateSystem (const glm::dmat4 &localToEcef, const glm::dmat4 &ecefToLocal)
 Create a new coordinate system with the specified transformations between the local frame and the Earth-Centered, Earth-Fixed frame. This is an advanced constructor and should be avoided in most cases.
const glm::dmat4 & getLocalToEcefTransformation () const noexcept
 Gets the transformation matrix from the local horizontal coordinate system managed by this instance to the Earth-Centered, Earth-Fixed Coordinates (ECEF).
const glm::dmat4 & getEcefToLocalTransformation () const noexcept
 Gets the transformation matrix from Earth-Centered, Earth-Fixed Coordinates (ECEF) to the local horizontal coordinate system managed by this instance.
glm::dvec3 localPositionToEcef (const glm::dvec3 &localPosition) const noexcept
 Converts a position in the local horizontal coordinate system managed by this instance to Earth-Centered, Earth-Fixed (ECEF).
glm::dvec3 ecefPositionToLocal (const glm::dvec3 &ecefPosition) const noexcept
 Converts a position in the Earth-Centered, Earth-Fixed (ECEF) coordinate system to the local horizontal coordinate system managed by this instance.
glm::dvec3 localDirectionToEcef (const glm::dvec3 &localDirection) const noexcept
 Converts a direction in the local horizontal coordinate system managed by this instance to Earth-Centered, Earth-Fixed (ECEF).
glm::dvec3 ecefDirectionToLocal (const glm::dvec3 &ecefDirection) const noexcept
 Converts a direction in the Earth-Centered, Earth-Fixed (ECEF) coordinate system to the local horizontal coordinate system managed by this instance.
glm::dmat4 computeTransformationToAnotherLocal (const LocalHorizontalCoordinateSystem &target) const noexcept
 Computes the transformation matrix from this local horizontal coordinate system to another one. For example, if the returned matrix is multiplied with a vector representing a position in this coordinate system, the result will be a new vector representing the position in the target coordinate system.
Each principal axis in the new coordinate system can be specified to point in a particular compass direction, or it can point up or down. In this way, a right-handed or left-handed coordinate system can be created.
Definition at line 29 of file LocalHorizontalCoordinateSystem.h.
◆ LocalHorizontalCoordinateSystem() [1/4]
CesiumGeospatial::LocalHorizontalCoordinateSystem::LocalHorizontalCoordinateSystem ( const Cartographic & origin,
LocalDirection xAxisDirection = LocalDirection::East,
LocalDirection yAxisDirection = LocalDirection::North,
LocalDirection zAxisDirection = LocalDirection::Up,
double scaleToMeters = 1.0,
const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 )
originThe origin of the coordinate system.
xAxisDirectionThe local direction in which the X axis points at the origin.
yAxisDirectionThe local direction in which the Y axis points at the origin.
zAxisDirectionThe local direction in which the Z axis points at the origin.
scaleToMetersLocal units are converted to meters by multiplying them by this factor. For example, if the local units are centimeters, this parameter should be 1.0 / 100.0.
ellipsoidThe ellipsoid on which the coordinate system is based.
◆ LocalHorizontalCoordinateSystem() [2/4]
CesiumGeospatial::LocalHorizontalCoordinateSystem::LocalHorizontalCoordinateSystem ( const glm::dvec3 & originEcef,
originEcefThe origin of the coordinate system.
◆ LocalHorizontalCoordinateSystem() [3/4]
CesiumGeospatial::LocalHorizontalCoordinateSystem::LocalHorizontalCoordinateSystem ( const glm::dmat4 & localToEcef)
explicit
This constructor can be used to save/restore the state of an instance. It can also be used to create unusual coordinate systems that can't be created by the other constructors, such as coordinate systems where the axes aren't aligned with compass directions.
localToEcefThe transformation matrix from this coordinate system to the ECEF frame.
◆ LocalHorizontalCoordinateSystem() [4/4]
CesiumGeospatial::LocalHorizontalCoordinateSystem::LocalHorizontalCoordinateSystem ( const glm::dmat4 & localToEcef,
const glm::dmat4 & ecefToLocal )
localToEcefThe transformation matrix from this coordinate system to the ECEF frame. This must be the inverse of ecefToLocal or behavior is undefined, but this is not enforced.
ecefToLocalThe transformation matrix from the ECEF frame to this coordinate system. This must be the inverse of localToEcef or behavior is undefined, but this is not enforced.
◆ computeTransformationToAnotherLocal()
glm::dmat4 CesiumGeospatial::LocalHorizontalCoordinateSystem::computeTransformationToAnotherLocal ( const LocalHorizontalCoordinateSystem & target) const
noexcept
targetThe other local horizontal coordinate system.
The transformation.
◆ ecefDirectionToLocal()
glm::dvec3 CesiumGeospatial::LocalHorizontalCoordinateSystem::ecefDirectionToLocal ( const glm::dvec3 & ecefDirection) const
noexcept
Because the vector is treated as a direction only, the translation portion of the transformation is ignored.
ecefDirectionThe direction in the ECEF coordinate system.
The equivalent direction in the local coordinate system.
◆ ecefPositionToLocal()
glm::dvec3 CesiumGeospatial::LocalHorizontalCoordinateSystem::ecefPositionToLocal ( const glm::dvec3 & ecefPosition) const
noexcept
ecefPositionThe position in the ECEF coordinate system.
The equivalent position in the local coordinate system.
◆ getEcefToLocalTransformation()
const glm::dmat4 & CesiumGeospatial::LocalHorizontalCoordinateSystem::getEcefToLocalTransformation ( ) const
inlinenoexcept
The transformation.
Definition at line 134 of file LocalHorizontalCoordinateSystem.h.
◆ getLocalToEcefTransformation()
const glm::dmat4 & CesiumGeospatial::LocalHorizontalCoordinateSystem::getLocalToEcefTransformation ( ) const
inlinenoexcept
The transformation.
Definition at line 124 of file LocalHorizontalCoordinateSystem.h.
◆ localDirectionToEcef()
glm::dvec3 CesiumGeospatial::LocalHorizontalCoordinateSystem::localDirectionToEcef ( const glm::dvec3 & localDirection) const
noexcept
localDirectionThe direction in the local coordinate system.
The equivalent direction in the ECEF coordinate system.
◆ localPositionToEcef()
glm::dvec3 CesiumGeospatial::LocalHorizontalCoordinateSystem::localPositionToEcef ( const glm::dvec3 & localPosition) const
noexcept
localPositionThe position in the local coordinate system.
The equivalent position in the ECEF coordinate system.
