Cesium Releases in July 2026
In June, we hosted about 400 3D geospatial enthusiasts in Philadelphia for the second Cesium Developer Conference. The excitement was contagious as users and Cesium + Bentley teammates learned from each other and shared their recent work. The many Cesium product announcements included two you can read more about in blog posts from earlier this week: upcoming vector data support in 3D Tiles and expanded BIM/CAD support and metadata queries. And if you couldn’t attend devcon, are curious about sessions you missed, or want to revisit your favorite talks, the video recordings for the entire conference will be posted in a few weeks.
Read on for recent release notes, and be on the lookout for more announcements in coming weeks, including integration of iTwin Capture into Cesium ion Self-Hosted for 3D model reconstruction from photos.
CesiumJS 1.143 release
CesiumJS 1.143 is now available. Highlights of the release include:
  • Added support for the KHR_meshopt_compression glTF extension, including the v1 attribute codec and the COLOR filter. #13553
  • Added PathGraphics.materialMode. A value of "PORTIONS" allows visualizing the path in segments with different materials specified by intervals or sampling. Each segment material is determined by the material property value at the corresponding simulation time. The default value of "WHOLE" preserves existing material behavior. #13530
  • Fixed a bug that caused crashes when using billboards in environments that replace Promise with custom promise implementations. #13475
A multiphase satellite maneuver visualized in CesiumJS using colored path segments.
Cesium for Unreal 2.28.0 release
Cesium for Unreal v2.28.0 is now available. This is the last release that will support Unreal 5.5. Future versions will require Unreal 5.6+. Highlights of this release include:
  • Added support for Unreal Engine 5.8.
  • Fixed a crash that could occur when zooming to a tileset with Update in Editor disabled.
  • Fixed Gaussian splats not rendering in Standalone Game sessions launched from the editor.
In addition to the above, this release updates cesium-native from v0.61.0 to v0.62.0. See the changelog for a complete list of changes in cesium-native.
Cesium for Unity 1.24.0 release
Cesium for Unity v1.24.0 is now available. Highlights of this release include:
  • Added support for rendering glTFs with line primitives.
glTF line primitives visualized in Cesium for Unity.
Cesium for Omniverse 0.29.0 release
Cesium for Omniverse v0.29.0 is now available. Highlights of this release include:
  • Cesium for Omniverse now requires Kit 110.0 or above (Isaac Sim 6.0.0-dev2 or above).
  • Fixed bug where polygon clipping was rendering black instead of discarding.
Cesium ion and tilers updates
Cesium ion SaaS
  • Users can import iModels from Bentley Infrastructure Cloud to Cesium ion to make them available for streaming as 3D Tiles.
  • Users can now convert NetCDF files into 3D Tiles through the voxel tiler.
  • Users can now convert GeoJSON data into 3D Tiles through the vector tiler.
Design tiler
  • Tweaked IFC swept circular geometry for more consistent rotational offsets.
Point clouds tiler
  • Coming soon: fixing an issue where PNTS attributes could have incorrect alignment if compression was turned off.
Powered by Cesium
NTT Software Innovation Center is conducting research and development on a computing architecture referred to as the “Space Data Center.” As part of the effort to support the design and validation of this architecture, NTT is using CesiumJS.
Inter-satellite communication links visualized in a distributed network architecture. Courtesy NTT.
分散ネットワークアーキテクチャにおける衛星間通信リンクの可視化。(提供:NTT)
