CesiumVectorTilesRasterOverlay.h
5#include <CesiumVectorOverlays/VectorStylingProvider.h>
6
8#include "CesiumIonServer.h"
10#include "CesiumRasterOverlay.h"
11#include "CesiumVectorStyle.h"
12#include "Components/ActorComponent.h"
13#include "CoreMinimal.h"
14#include "Delegates/Delegate.h"
15#include "CesiumVectorTilesRasterOverlay.generated.h"
16
17/**
18 * Determines the styling provider to be used to provide styling information for
19 * individual features.
20 */
21UENUM()
23 None = 0 UMETA(ToolTip = "Only the default style will be used."),
25 ToolTip =
26 "Uses the Blueprint class implementing the ICesiumVectorTilesStylingCallbacks interface specified in BlueprintStylingProvider."),
28 ToolTip =
29 "Calls the TFunction specified on the overlay using C++ to create a VectorStylingProvider directly.")
30};
31
32UINTERFACE(Blueprintable, MinimalAPI)
33class UCesiumVectorTilesStylingCallbacks : public UInterface {
34 GENERATED_BODY()
35};
36
38 GENERATED_BODY()
39
40public:
41 /**
42 * This function is called before styling begins. It should be used to look up
43 * metadata property tables and store them for use in the styling functions.
44 */
45 UFUNCTION(
46 BlueprintCallable,
47 BlueprintNativeEvent,
48 Category = "Cesium|Styling")
49 void OnStylingBegin(const FCesiumModelMetadata& InModelMetadata);
50 virtual void
52
53 /**
54 * This function is called for each individual point feature.
55 *
56 * If it returns false, the default style will be used for this feature. If it
57 * returns true, the "Out Point Style" will be used for this feature.
58 */
59 UFUNCTION(
60 BlueprintCallable,
61 BlueprintNativeEvent,
62 Category = "Cesium|Styling")
64 int64 InFeatureId,
65 const FVector& InPointLlh,
66 FCesiumVectorPointStyle& OutPointStyle);
68 int64 InFeatureId,
69 const FVector& InPointLlh,
70 FCesiumVectorPointStyle& OutPointStyle) {
71 return false;
72 }
73
74 /**
75 * This function is called for each individual polyline feature.
76 *
77 * If it returns false, the default style will be used for this feature. If it
78 * returns true, the "Out Line Style" will be used for this feature.
79 */
80 UFUNCTION(
81 BlueprintCallable,
82 BlueprintNativeEvent,
83 Category = "Cesium|Styling")
85 int64 InFeatureId,
86 const TArray<FVector>& InPolylineLlh,
87 FCesiumVectorLineStyle& OutLineStyle);
89 int64 InFeatureId,
90 const TArray<FVector>& InPolylineLlh,
91 FCesiumVectorLineStyle& OutLineStyle) {
92 return false;
93 }
94
95 /**
96 * This function is called for each individual polygon feature.
97 *
98 * If it returns false, the default style will be used for this feature. If it
99 * returns true, the "Out Polygon Style" will be used for this feature.
100 */
101 UFUNCTION(
102 BlueprintCallable,
103 BlueprintNativeEvent,
104 Category = "Cesium|Styling")
106 int64 InFeatureId,
107 const TArray<FVector>& InPolygonLlh,
108 FCesiumVectorPolygonStyle& OutPolygonStyle);
110 int64 InFeatureId,
111 const TArray<FVector>& InPolygonLlh,
112 FCesiumVectorPolygonStyle& OutPolygonStyle) {
113 return false;
114 }
115};
116
117/**
118 * Configures where the CesiumVectorTilesRasterOverlay should load its vector
119 * data from.
120 */
121UENUM(BlueprintType)
123 /**
124 * The raster overlay will load a vector tileset from Cesium ion.
125 */
127 /**
128 * The raster overlay will load a vector tileset from a URL.
129 */
131};
132
133UCLASS(
134 ClassGroup = Cesium,
135 BlueprintType,
137 meta = (BlueprintSpawnableComponent))
138class CESIUMRUNTIME_API UCesiumVectorTilesRasterOverlay
139 : public UCesiumRasterOverlay {
140 GENERATED_BODY()
141
142public:
143 UPROPERTY(EditAnywhere, BlueprintReadWrite, Category = "Cesium")
146 /**
147 * The ID of the Cesium ion asset to use.
148 */
149 UPROPERTY(
150 EditAnywhere,
151 BlueprintReadWrite,
152 Category = "Cesium",
153 meta =
154 (EditCondition =
155 "Source == ECesiumVectorTilesRasterOverlaySource::FromCesiumIon"))
157
158 /**
159 * The access token to use to access the Cesium ion resource.
160 */
161 UPROPERTY(
162 EditAnywhere,
163 BlueprintReadWrite,
164 Category = "Cesium",
165 meta =
166 (EditCondition =
167 "Source == ECesiumVectorTilesRasterOverlaySource::FromCesiumIon"))
169
170 /**
171 * The Cesium ion Server from which this raster overlay is loaded.
172 */
173 UPROPERTY(
174 EditAnywhere,
175 BlueprintReadWrite,
176 Category = "Cesium",
177 AdvancedDisplay,
178 meta =
179 (EditCondition =
180 "Source == ECesiumVectorTilesRasterOverlaySource::FromCesiumIon"))
182
183 /**
184 * A URL to load a vector tiles tileset from.
185 */
186 UPROPERTY(
187 EditAnywhere,
188 BlueprintReadWrite,
189 Category = "Cesium",
190 meta =
191 (EditCondition =
192 "Source == ECesiumVectorTilesRasterOverlaySource::FromUrl"))
193 FString Url;
194
195 /**
196 * Headers to use while making a request to `Url` to load a vector tiles
197 * tileset.
198 */
199 UPROPERTY(
200 EditAnywhere,
201 BlueprintReadWrite,
202 Category = "Cesium",
203 meta =
204 (EditCondition =
205 "Source == ECesiumVectorTilesRasterOverlaySource::FromUrl"))
206 TMap<FString, FString> RequestHeaders;
207
208 /**
209 * The number of mip levels to generate for each tile of this raster overlay.
210 *
211 * Additional mip levels can improve the visual quality of tiles farther from
212 * the camera at the cost of additional rasterization time to create each mip
213 * level.
214 */
215 UPROPERTY(
216 EditAnywhere,
217 BlueprintReadWrite,
218 Category = "Cesium",
219 meta = (ClampMin = "0", ClampMax = "8"))
220 int32 MipLevels = 0;
221
222 /**
223 * The default style to use for this raster overlay.
224 *
225 * If no style information is present in the vector tiles tileset, this style
226 * will be used instead.
227 */
228 UPROPERTY(EditAnywhere, BlueprintReadWrite, Category = "Cesium|Styling")
230
231 /**
232 * The styling provider to use to apply styling information to individual
233 * features.
234 *
235 * If this is set to None, the DefaultStyle will be used for all features.
236 */
237 UPROPERTY(EditAnywhere, BlueprintReadWrite, Category = "Cesium|Styling")
240
241 /**
242 * The Blueprint class that will be instantiated to provide styling
243 * information for features when StylingProviderType is set to Blueprint.
244 *
245 * Because Blueprints in Unreal need to run on the main thread, a Blueprint
246 * styling provider can cause significant performance degradation when styling
247 * large numbers of features. If improved performance is required, styling via
248 * C++ via the LambdaStylingProvider property should be used instead.
249 */
250 UPROPERTY(
251 EditAnywhere,
252 BlueprintReadWrite,
253 Category = "Cesium|Styling",
254 meta =
255 (EditCondition =
256 "StylingProviderType == ECesiumVectorStylingProviderType::Blueprint",
257 MustImplement =
258 "/Script/CesiumRuntime.CesiumVectorTilesStylingCallbacks"))
259 TSubclassOf<UObject> BlueprintStylingProvider;
260
261 /**
262 * The lambda that will be called to instantiate a
263 * `CesiumVectorOverlays::VectorStylingProvider` when StylingProviderType is
264 * set to Lambda.
265 */
266 TOptional<
267 TFunction<std::shared_ptr<CesiumVectorOverlays::VectorStylingProvider>()>>
269
270protected:
271 virtual std::unique_ptr<CesiumRasterOverlays::RasterOverlay> CreateOverlay(
272 const CesiumRasterOverlays::RasterOverlayOptions& options = {}) override;
273
274private:
275 UPROPERTY(Transient)
276 UObject* _pStylingInterfaceObject;
277};
@ UMETA
The tileset will be loaded from Cesium Ion using the provided IonAssetID and IonAccessToken.
@ Blueprint
Visual styles for each feature are evaluated in Blueprints before being passed to the generated mater...
@ FromCesiumIon
The raster overlay will load a GeoJsonDocument from Cesium ion.
@ FromUrl
The raster overlay will load a GeoJsonDocument from a URL.
Blueprintable
Determines the styling provider to be used to provide styling information for individual features.
Configures where the CesiumVectorTilesRasterOverlay should load its vector data from.
@ FromCesiumIon
bool OnStylePoint(int64 InFeatureId, const FVector &InPointLlh, FCesiumVectorPointStyle &OutPointStyle)
virtual bool OnStylePoint_Implementation(int64 InFeatureId, const FVector &InPointLlh, FCesiumVectorPointStyle &OutPointStyle)
virtual void OnStylingBegin_Implementation(const FCesiumModelMetadata &InModelMetadata)
bool OnStylePolygon(int64 InFeatureId, const TArray< FVector > &InPolygonLlh, FCesiumVectorPolygonStyle &OutPolygonStyle)
virtual bool OnStylePolyline_Implementation(int64 InFeatureId, const TArray< FVector > &InPolylineLlh, FCesiumVectorLineStyle &OutLineStyle)
virtual bool OnStylePolygon_Implementation(int64 InFeatureId, const TArray< FVector > &InPolygonLlh, FCesiumVectorPolygonStyle &OutPolygonStyle)
bool OnStylePolyline(int64 InFeatureId, const TArray< FVector > &InPolylineLlh, FCesiumVectorLineStyle &OutLineStyle)
void OnStylingBegin(const FCesiumModelMetadata &InModelMetadata)
Defines a Cesium ion Server.
TSubclassOf< UObject > BlueprintStylingProvider
The Blueprint class that will be instantiated to provide styling information for features when Stylin...
TMap< FString, FString > RequestHeaders
Headers to use while making a request to Url to load a vector tiles tileset.
ECesiumVectorTilesRasterOverlaySource Source
int64 IonAssetID
UCesiumIonServer * CesiumIonServer
int32 MipLevels
FString Url
FString IonAccessToken
FCesiumVectorStyle DefaultStyle
ECesiumVectorStylingProviderType StylingProviderType
The styling provider to use to apply styling information to individual features.
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay(const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
TOptional< TFunction< std::shared_ptr< CesiumVectorOverlays::VectorStylingProvider >()> > LambdaStylingProvider
The lambda that will be called to instantiate a CesiumVectorOverlays::VectorStylingProvider when Styl...
STL namespace.
A blueprint-accessible wrapper for metadata contained in a glTF model.
The style used to draw polylines and strokes.
The style used to draw polygons.
Style information to use when drawing vector data.
