UCesiumIonServer Class Reference
Defines a Cesium ion Server. More...
#include <CesiumIonServer.h>
Inheritance diagram for UCesiumIonServer:
static UCesiumIonServer * GetDefaultServer ()
 Gets the default Cesium ion Server (ion.cesium.com).
static UCesiumIonServer * GetServerForNewObjects ()
 Gets the current server to be assigned to new objects.
static void SetServerForNewObjects (UCesiumIonServer *Server)
 Sets the current server to be assigned to new objects.
FString DisplayName = "ion.cesium.com"
 The name to display for this server.
FString ServerUrl = "https://ion.cesium.com"
 The main URL of the Cesium ion server.
FString ApiUrl = "https://api.cesium.com"
 The URL of the main API endpoint of the Cesium ion server.
int64 OAuth2ApplicationID = 190
 The application ID to use to log in to this server using OAuth2.
FString DefaultIonAccessTokenId
 The ID of the default access token to use to access Cesium ion assets at runtime.
 The default token used to access Cesium ion assets at runtime.
This may be the public (SaaS) Cesium ion server at ion.cesium.com, or it may be a self-hosted instance.
Definition at line 18 of file CesiumIonServer.h.
◆ GetDefaultServer()
static UCesiumIonServer * UCesiumIonServer::GetDefaultServer ( )
static
It is expected to be found at /Game/CesiumSettings/CesiumIonServers/CesiumIonSaaS. In the Editor, it will be created if it does not already exist, so this method always returns a valid instance. At runtime, this method returns nullptr if the object does not exist.
◆ GetServerForNewObjects()
static UCesiumIonServer * UCesiumIonServer::GetServerForNewObjects ( )
static
In the Editor, this is the server that is currently selected on the Cesium panel. At runtime, this returns GetDefault, unless SetCurrentForNewObjects has been called to set it to something different.
◆ SetServerForNewObjects()
static void UCesiumIonServer::SetServerForNewObjects ( UCesiumIonServer * Server)
static
If set to nullptr, the value of GetDefault will be returned from GetCurrentForNewObjects.
◆ ApiUrl
FString UCesiumIonServer::ApiUrl = "https://api.cesium.com"
For example, for the default, public Cesium ion server, this is https://api.cesium.com. If left blank, the API URL is automatically inferred from the Server URL.
Definition at line 91 of file CesiumIonServer.h.
◆ DefaultIonAccessToken
FString UCesiumIonServer::DefaultIonAccessToken
This token is embedded in packaged games for use at runtime.
Definition at line 129 of file CesiumIonServer.h.
◆ DefaultIonAccessTokenId
FString UCesiumIonServer::DefaultIonAccessTokenId
This property may be an empty string, in which case the ID is found by searching the logged-in Cesium ion account for the DefaultIonAccessToken.
Definition at line 117 of file CesiumIonServer.h.
◆ DisplayName
FString UCesiumIonServer::DisplayName = "ion.cesium.com"
Definition at line 66 of file CesiumIonServer.h.
◆ OAuth2ApplicationID
int64 UCesiumIonServer::OAuth2ApplicationID = 190
This OAuth2 application must be configured on the server with the exact URL http://127.0.0.1/cesium-for-unreal/oauth2/callback.
Definition at line 104 of file CesiumIonServer.h.
◆ ServerUrl
FString UCesiumIonServer::ServerUrl = "https://ion.cesium.com"
For example, the server URL for the public Cesium ion is https://ion.cesium.com.
Definition at line 78 of file CesiumIonServer.h.
