Cesium for Unreal 2.31.0
A quadtree pyramid of 2D raster images meant to be draped over a Cesium 3D Tileset. More...
#include <CesiumRasterOverlay.h>
| UCesiumRasterOverlay () | |
| void | AddToTileset () |
| Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state. | |
| void | RemoveFromTileset () |
| Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor. | |
| void | Refresh () |
| Refreshes this overlay by removing from its owning Cesium 3D Tileset Actor and re-adding it. | |
| double | GetMaximumScreenSpaceError () const |
| void | SetMaximumScreenSpaceError (double Value) |
| int32 | GetMaximumTextureSize () const |
| void | SetMaximumTextureSize (int32 Value) |
| int32 | GetMaximumSimultaneousTileLoads () const |
| void | SetMaximumSimultaneousTileLoads (int32 Value) |
| int64 | GetSubTileCacheBytes () const |
| void | SetSubTileCacheBytes (int64 Value) |
| virtual void | Activate (bool bReset) override |
| Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed. | |
| virtual void | Deactivate () override |
| Deactivates this raster overlay. | |
| virtual void | OnComponentDestroyed (bool bDestroyingHierarchy) override |
| virtual bool | IsReadyForFinishDestroy () override |
| FString | MaterialLayerKey = "Overlay0" |
| The key to use to match this overlay to a material layer. | |
| FRasterOverlayRendererOptions | rendererOptions |
| Sets the texture filter and texture group of raster tile images. | |
| Cesium3DTilesSelection::Tileset * | FindTileset () const |
| virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > | CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) 0 |
| virtual void | OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay) |
| virtual void | OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay) |
Protected Attributes | |
| double | MaximumScreenSpaceError = 2.0 |
| The maximum number of pixels of error when rendering this overlay. | |
| int32 | MaximumTextureSize = 2048 |
| The maximum texel size of raster overlay textures, in either direction. | |
| int32 | MaximumSimultaneousTileLoads = 20 |
| The maximum number of overlay tiles that may simultaneously be in the process of loading. | |
| int64 | SubTileCacheBytes = 16 * 1024 * 1024 |
| The maximum number of bytes to use to cache sub-tiles in memory. | |
| bool | ShowCreditsOnScreen |
| Whether or not to show credits of this raster overlay on screen. | |
Raster overlays are commonly used for satellite imagery, street maps, and more.
Definition at line 54 of file CesiumRasterOverlay.h.
| UCesiumRasterOverlay::UCesiumRasterOverlay | ( | ) |
overridevirtual |
The overlay will continue to be shown on the tileset until it is deactivated.
If the overlay is already displayed on the Cesium3DTileset, calling this function will not cause it to pick up any new values for properties that have been modified since it was added. To do that, call Refresh.
If you created this overlay component via Blueprints, consider setting the "Auto Activate" property to false on the "Add Component" node and calling Activate after setting all the desired properties. This will avoid the need to call Refresh, and will ensure the overlay is not loaded multiple times.
| bReset | Whether the activation should happen even if ShouldActivate returns false. |
| void UCesiumRasterOverlay::AddToTileset | ( | ) |
It is usually better to call Activate rather than this function, in order to ensure that the component is also activated. Otherwise, if the Cesium3DTileset is reloaded for any reason, this overlay will no longer be shown.
If the overlay is already added or if this component's Owner is not a Cesium 3D Tileset, this method does nothing.
protectedvirtual |
Reimplemented in UCesiumAzureMapsRasterOverlay, UCesiumBingMapsRasterOverlay, UCesiumGeoJsonDocumentRasterOverlay, UCesiumGoogleMapTilesRasterOverlay, UCesiumPolygonRasterOverlay, UCesiumTileMapServiceRasterOverlay, UCesiumUrlTemplateRasterOverlay, UCesiumVectorTilesRasterOverlay, UCesiumWebMapServiceRasterOverlay, and UCesiumWebMapTileServiceRasterOverlay.
overridevirtual |
This will stop displaying it on the Cesium3DTileset to which the component is attached. The overlay will not be shown again until the component is re-activated.
protected |
| double UCesiumRasterOverlay::GetMaximumScreenSpaceError | ( | ) | const |
| int32 UCesiumRasterOverlay::GetMaximumSimultaneousTileLoads | ( | ) | const |
| int32 UCesiumRasterOverlay::GetMaximumTextureSize | ( | ) | const |
| int64 UCesiumRasterOverlay::GetSubTileCacheBytes | ( | ) | const |
overridevirtual |
inlineprotectedvirtual |
Reimplemented in UCesiumPolygonRasterOverlay.
Definition at line 251 of file CesiumRasterOverlay.h.
overridevirtual |
Definition at line 254 of file CesiumRasterOverlay.h.
| void UCesiumRasterOverlay::Refresh | ( | ) |
If this component's Owner is not a Cesium 3D Tileset Actor, this method does nothing. If this component is not active, the overlay will be removed from the Cesium3DTileset if already present but not re-added.
| void UCesiumRasterOverlay::RemoveFromTileset | ( | ) |
It is usually better to call Deactivate rather than this function, in order to ensure that the component is also deactivated. Otherwise, if the component remains active and the Cesium3DTileset is reloaded for any reason, this overlay will reappear.
If the overlay is not yet added or if this component's Owner is not a Cesium 3D Tileset, this method does nothing.
| void UCesiumRasterOverlay::SetMaximumScreenSpaceError | ( | double | Value | ) |
| void UCesiumRasterOverlay::SetMaximumSimultaneousTileLoads | ( | int32 | Value | ) |
| void UCesiumRasterOverlay::SetMaximumTextureSize | ( | int32 | Value | ) |
| void UCesiumRasterOverlay::SetSubTileCacheBytes | ( | int64 | Value | ) |
| FString UCesiumRasterOverlay::MaterialLayerKey = "Overlay0" |
When using Material Layers, any material layers inside a "Cesium" layer stack with a name that matches this name will have their Texture, TranslationScale, and TextureCoordinateIndex properties set automatically so that a ML_CesiumOverlay layer function (or similar) will correctly sample from this overlay.
Definition at line 68 of file CesiumRasterOverlay.h.
protected |
This is used to select an appropriate level-of-detail.
When this property has its default value, 2.0, it means that raster overlay images will be sized so that, when zoomed in closest, a single pixel in the raster overlay maps to approximately 2x2 pixels on the screen.
Definition at line 185 of file CesiumRasterOverlay.h.
protected |
Definition at line 213 of file CesiumRasterOverlay.h.
protected |
Images created by this overlay will be no more than this number of texels in either direction. This may result in reduced raster overlay detail in some cases.
Definition at line 201 of file CesiumRasterOverlay.h.
| FRasterOverlayRendererOptions UCesiumRasterOverlay::rendererOptions |
Depending on the project settings, the default texture filter, TF_Default, should have the best quality.
Definition at line 76 of file CesiumRasterOverlay.h.
protected |
Definition at line 237 of file CesiumRasterOverlay.h.
protected |
This is used by provider types that have an underlying tiling scheme that may not align with the tiling scheme of the geometry tiles on which the raster overlay tiles are draped. Because a single sub-tile may overlap multiple geometry tiles, it is useful to cache loaded sub-tiles in memory in case they're needed again soon. This property controls the maximum size of that cache.
Definition at line 231 of file CesiumRasterOverlay.h.
