CesiumIonServer.h
5#include "Engine/DataAsset.h"
6#include "UObject/Object.h"
7#include "CesiumIonServer.generated.h"
9namespace CesiumAsync {
10template <typename T> class Future;
11}
12
13/**
14 * Defines a Cesium ion Server. This may be the public (SaaS) Cesium ion server
15 * at ion.cesium.com, or it may be a self-hosted instance.
16 */
17UCLASS(BlueprintType)
18class CESIUMRUNTIME_API UCesiumIonServer : public UDataAsset {
19 GENERATED_BODY()
20
21public:
22 /**
23 * Gets the default Cesium ion Server (ion.cesium.com).
24 *
25 * It is expected to be found at
26 * `/Game/CesiumSettings/CesiumIonServers/CesiumIonSaaS`. In the Editor, it
27 * will be created if it does not already exist, so this method always returns
28 * a valid instance. At runtime, this method returns nullptr if the object
29 * does not exist.
30 */
31 UFUNCTION(BlueprintCallable, Category = "Cesium|ion")
33
34 /**
35 * Gets the current server to be assigned to new objects. In the Editor, this
36 * is the server that is currently selected on the Cesium panel. At runtime,
37 * this returns `GetDefault`, unless `SetCurrentForNewObjects` has been called
38 * to set it to something different.
39 */
41
42 /**
43 * Sets the current server to be assigned to new objects. If set to nullptr,
44 * the value of `GetDefault` will be returned from `GetCurrentForNewObjects`.
45 */
47
48#if WITH_EDITOR
49 /**
50 * Gets or creates a server from a given API URL. This is used for backward
51 * compatibility with the old `IonAssetEndpointUrl` property. The new server,
52 * if needed, is created in `/Game/CesiumSettings/CesiumIonServers`.
53 */
54 static UCesiumIonServer* GetBackwardCompatibleServer(const FString& apiUrl);
55#endif
56
57 /**
58 * The name to display for this server.
59 */
60 UPROPERTY(
61 EditAnywhere,
62 AssetRegistrySearchable,
63 BlueprintReadOnly,
64 Category = "Cesium|ion",
65 meta = (DisplayName = "Display Name"))
66 FString DisplayName = "ion.cesium.com";
67
68 /**
69 * The main URL of the Cesium ion server. For example, the server URL for the
70 * public Cesium ion is https://ion.cesium.com.
71 */
72 UPROPERTY(
73 EditAnywhere,
74 AssetRegistrySearchable,
75 BlueprintReadOnly,
76 Category = "Cesium|ion",
77 meta = (DisplayName = "Server URL"))
78 FString ServerUrl = "https://ion.cesium.com";
79
80 /**
81 * The URL of the main API endpoint of the Cesium ion server. For example, for
82 * the default, public Cesium ion server, this is `https://api.cesium.com`. If
83 * left blank, the API URL is automatically inferred from the Server URL.
84 */
85 UPROPERTY(
86 EditAnywhere,
87 AssetRegistrySearchable,
88 BlueprintReadOnly,
89 Category = "Cesium|ion",
90 meta = (DisplayName = "API URL"))
91 FString ApiUrl = "https://api.cesium.com";
92
93 /**
94 * The application ID to use to log in to this server using OAuth2. This
95 * OAuth2 application must be configured on the server with the exact URL
96 * `http://127.0.0.1/cesium-for-unreal/oauth2/callback`.
97 */
98 UPROPERTY(
99 EditAnywhere,
100 AssetRegistrySearchable,
101 BlueprintReadOnly,
102 Category = "Cesium|ion",
103 meta = (DisplayName = "OAuth Application ID"))
105
106 /**
107 * The ID of the default access token to use to access Cesium ion assets at
108 * runtime. This property may be an empty string, in which case the ID is
109 * found by searching the logged-in Cesium ion account for the
110 * DefaultIonAccessToken.
111 */
112 UPROPERTY(
113 EditAnywhere,
114 BlueprintReadOnly,
115 Category = "Cesium|ion",
116 meta = (DisplayName = "Default Cesium ion Access Token ID"))
118
119 /**
120 * The default token used to access Cesium ion assets at runtime. This token
121 * is embedded in packaged games for use at runtime.
122 */
123 UPROPERTY(
124 EditAnywhere,
125 AssetRegistrySearchable,
126 BlueprintReadOnly,
127 Category = "Cesium|ion",
128 meta = (DisplayName = "Default Cesium ion Access Token"))
130
131#if WITH_EDITOR
132 /**
133 * If the `ApiUrl` property is blank, this method asynchronously resolves it
134 * by consulting with the `ServerUrl`. If the `ApiUrl` is not blank, this
135 * method returns an already-resolved future.
136 */
137 CesiumAsync::Future<void> ResolveApiUrl();
138#endif
139
140private:
141 static UCesiumIonServer* _pDefaultForNewObjects;
142};
static UCesiumIonServer * GetDefaultServer()
static void SetServerForNewObjects(UCesiumIonServer *Server)
FString DefaultIonAccessToken
int64 OAuth2ApplicationID
static UCesiumIonServer * GetServerForNewObjects()
FString DisplayName
FString ServerUrl
FString ApiUrl
FString DefaultIonAccessTokenId
The ID of the default access token to use to access Cesium ion assets at runtime.
