CesiumFeaturesMetadataDescription.h
9#include "Containers/Array.h"
10#include "Containers/UnrealString.h"
11#include "Misc/Guid.h"
12
13#include "CesiumFeaturesMetadataDescription.generated.h"
14
15#pragma region Features descriptions
16
17/**
18 * @brief Determines how features in a Cesium3DTileset will be visually styled.
19 */
20UENUM()
21enum class ECesiumFeatureStylingMode : uint8 {
22 /**
23 * Metadata values are passed through textures to the generated material. This
24 * enables numeric properties to be used with typical material logic.
25 *
26 * Due to limitations with Unreal materials, properties that contain strings,
27 * matrices, and arrays may not be able to be properly encoded.
28 */
30 /**
31 * Visual styles for each feature are evaluated in Blueprints before being
32 * passed to the generated material. This enables flexible interaction with
33 * metadata properties that are not supported in materials, such as strings
34 * and big integers. However, this can impact performance since Blueprints are
35 * executed on the main thread.
36 *
37 * The class assigned to BlueprintStyleClass on the component must implement
38 * the ICesium3DTilesStylingProvider interface.
39 */
41};
42
43/**
44 * @brief Description of a feature ID set from either EXT_mesh_features or
45 * EXT_instance_features.
46 */
47USTRUCT()
48struct CESIUMRUNTIME_API FCesiumFeatureIdSetDescription {
49 GENERATED_USTRUCT_BODY()
50
51 /**
52 * The display name of the feature ID set. If the feature ID set already has a
53 * label, this will use the label. Otherwise, if the feature ID set is
54 * unlabeled, a name will be generated like so:
55 *
56 * - If the feature ID set is an attribute, this will appear as
57 * "_FEATURE_ID_<index>", where <index> is the set index specified in
58 * the attribute.
59 * - If the feature ID set is a texture, this will appear as
60 * "_FEATURE_ID_TEXTURE_<index>", where <index> increments with the number
61 * of feature ID textures seen in an individual primitive.
62 * - If the feature ID set is an implicit set, this will appear as
63 * "_IMPLICIT_FEATURE_ID". Implicit feature ID sets don't vary in definition,
64 * so any additional implicit feature ID sets across the primitives are
65 * counted by this one.
66 *
67 * This name will also be used to represent the feature ID set in the
68 * generated material.
69 */
70 UPROPERTY(EditAnywhere, Category = "Cesium|Features")
71 FString Name;
72
73 /**
74 * The type of the feature ID set.
75 */
76 UPROPERTY(EditAnywhere, Category = "Cesium|Features")
78
79 /**
80 * The name of the property table that this feature ID set corresponds to.
81 */
82 UPROPERTY(EditAnywhere, Category = "Cesium|Features")
84
85 /**
86 * The method used to apply styling to individual features.
87 *
88 * By default, metadata properties are encoded to textures and passed the
89 * generated material, allowing use with material logic. However, they can
90 * also be styled in a prepass using Blueprints.
91 */
92 UPROPERTY(EditAnywhere, Category = "Cesium|Features")
94};
95
96/**
97 * @brief Description of the feature ID sets available from the
98 * EXT_mesh_features and EXT_instance_features extensions in a glTF.
99 *
100 * This aggregates the feature ID sets of all visible glTF primitives in the
101 * model. This describes the feature IDs that can be made accessible
102 * to Unreal Engine materials.
103 */
104USTRUCT()
105struct CESIUMRUNTIME_API FCesiumPrimitiveFeaturesDescription {
106 GENERATED_USTRUCT_BODY()
107
108 /**
109 * @brief The feature ID sets to make accessible to the material. Note that
110 * the order of feature ID sets in this array does not necessarily
111 * correspond to the order of these feature ID sets in a glTF
112 * primitive.
113 */
114 UPROPERTY(
115 EditAnywhere,
116 Category = "Cesium|Features",
117 Meta = (TitleProperty = "Name"))
119};
120#pragma endregion
121
122#pragma region Metadata descriptions
123
124// These don't exhaustively cover the possibilities of glTF metadata
125// classes, they only cover the subset that can be encoded into textures. The
126// following types are excluded:
127// - enums
128// - strings that cannot be parsed as numbers or colors
129// - matrices
130// - variable length arrays
131// - arrays of non-scalar, non-boolean elements
132//
133// Additionally, if a property contains fixed-length arrays, only the first four
134// elements can be encoded.
135
136/**
137 * @brief Description of a property table property that should be encoded for
138 * access on the GPU.
139 */
140USTRUCT()
142 GENERATED_USTRUCT_BODY()
143
144 /**
145 * The name of this property. This will be how it is referenced in the
146 * material.
147 */
148 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
149 FString Name;
150
151 /**
152 * Describes the underlying type of this property and other relevant
153 * information from its EXT_structural_metadata definition. Not all types of
154 * properties can be encoded to the GPU, or coerced to GPU-compatible types.
155 */
156 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
158
159 /**
160 * Describes how the property will be encoded as data on the GPU, if possible.
161 */
162 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
164};
165
166/**
167 * @brief Description of a property table containing properties to be encoded
168 * for access in Unreal materials.
169 */
170USTRUCT()
171struct CESIUMRUNTIME_API FCesiumPropertyTableDescription {
172 GENERATED_USTRUCT_BODY()
173
174 /**
175 * @brief The name of this property table. If this property table has no name
176 * in the EXT_structural_metadata extension, then its class name is used
177 * instead.
178 */
179 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
180 FString Name;
181
182 /**
183 * @brief Descriptions of the properties to upload to the GPU.
184 */
185 UPROPERTY(
186 EditAnywhere,
187 Category = "Cesium|Metadata",
188 Meta = (TitleProperty = "Name"))
190};
191
192/**
193 * @brief Description of a property texture property that should be made
194 * accessible to Unreal materials. A property texture property's data is
195 * already available through a texture, so no additional encoding details need
196 * to be specified.
197 */
198USTRUCT()
200 GENERATED_USTRUCT_BODY()
201
202 /**
203 * The name of this property. This will be how it is referenced in the
204 * material.
205 */
206 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
207 FString Name;
208
209 /**
210 * Describes the underlying type of this property and other relevant
211 * information from its EXT_structural_metadata definition.
212 */
213 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
215};
216
217/**
218 * @brief Description of a property texture with properties that should be
219 * made accessible to Unreal materials.
220 */
221USTRUCT()
222struct CESIUMRUNTIME_API FCesiumPropertyTextureDescription {
223 GENERATED_USTRUCT_BODY()
224
225 /**
226 * @brief The name of this property texture.
227 */
228 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata")
229 FString Name;
230
231 /**
232 * @brief Descriptions of the properties to upload to the GPU.
233 */
234 UPROPERTY(
235 EditAnywhere,
236 Category = "Cesium|Metadata",
237 Meta = (TitleProperty = "Name"))
239};
240
241/**
242 * @brief Description of a property attribute property that should be encoded
243 * for access on the GPU.
244 *
245 * This is similar to FCesiumPropertyTablePropertyDescription, but is limited to
246 * the types that are supported for property attribute properties.
247 */
248USTRUCT()
250 GENERATED_USTRUCT_BODY()
251
252 /**
253 * The name of this property. This will be how it is referenced in the
254 * material.
255 */
256 UPROPERTY(EditAnywhere, Category = "Cesium")
257 FString Name;
258
259 /**
260 * Describes the underlying type of this property and other relevant
261 * information from its EXT_structural_metadata definition. Not all types of
262 * properties can be encoded to the GPU, or coerced to GPU-compatible types.
263 */
264 UPROPERTY(EditAnywhere, Category = "Cesium")
266
267 /**
268 * Describes how the property will be encoded as data on the GPU, if possible.
269 */
270 UPROPERTY(EditAnywhere, Category = "Cesium")
272};
273
274/**
275 * @brief Description of a property attribute with properties that should be
276 * made accessible to Unreal materials.
277 */
278USTRUCT()
279struct CESIUMRUNTIME_API FCesiumPropertyAttributeDescription {
280 GENERATED_USTRUCT_BODY()
281
282 /**
283 * @brief The name of this property attribute.
284 */
285 UPROPERTY(EditAnywhere, Category = "Cesium")
286 FString Name;
287
288 /**
289 * @brief Descriptions of the properties to upload to the GPU.
290 */
291 UPROPERTY(EditAnywhere, Category = "Cesium", Meta = (TitleProperty = "Name"))
293};
294
295/**
296 * @brief Names of the metadata entities referenced by the
297 * EXT_structural_metadata on a glTF's primitives.
298 *
299 * This aggregates the metadata of all visible glTF primitives in the model.
300 * This lists the names of the property textures actually used by the glTF
301 * primitive, indicating it can be sampled with the primitive's texture
302 * coordinates in the Unreal material.
303 */
304USTRUCT()
305struct CESIUMRUNTIME_API FCesiumPrimitiveMetadataDescription {
306 GENERATED_USTRUCT_BODY()
307
308 /**
309 * @brief The names of the property textures used by the glTF primitives
310 * across the tileset.
311 *
312 * This should be a subset of the property textures listed in the model
313 * metadata. Property textures can be passed to the material even if they are
314 * not explicitly used by a glTF primitive, but the primitive may lack the
315 * corresponding sets of texture coordinates intended to sample them.
316 */
317 UPROPERTY(
318 EditAnywhere,
319 Category = "Cesium|Metadata",
320 Meta = (TitleProperty = "Name"))
321 TSet<FString> PropertyTextureNames;
322};
323
324/**
325 * @brief Description of metadata from a glTF's EXT_structural_metadata
326 * extension that should be uploaded to the GPU for access in Unreal materials.
327 */
328USTRUCT()
329struct CESIUMRUNTIME_API FCesiumModelMetadataDescription {
330 GENERATED_USTRUCT_BODY()
331
332 /**
333 * @brief Descriptions of property tables to encode for access in Unreal
334 * materials.
335 */
336 UPROPERTY(
337 EditAnywhere,
338 Category = "Cesium|Metadata",
339 Meta = (TitleProperty = "Name"))
341
342 /**
343 * @brief Descriptions of property textures to make accessible to Unreal
344 * materials.
345 */
346 UPROPERTY(
347 EditAnywhere,
348 Category = "Cesium|Metadata",
349 Meta = (TitleProperty = "Name"))
351};
352
353#pragma endregion
354
355#pragma region Tileset Statistics
356
357/**
358 * @brief Supported statistic semantics from the 3D Tiles specification.
359 */
360UENUM()
362 None = 0 UMETA(Hidden),
363 /**
364 * The minimum property value occurring in the tileset.
365 */
367 /**
368 * The maximum property value occurring in the tileset.
369 */
371 /**
372 * The arithmetic mean of property values occurring in the tileset.
373 */
375 /**
376 * The median of property values occurring in the tileset.
377 */
379 /**
380 * The standard deviation of property values occurring in the tileset.
381 */
383 /**
384 * The variance of property values occurring in the tileset.
385 */
387 /**
388 * The sum of property values occurring in the tileset.
389 */
391};
392
393/**
394 * @brief A statistic for a metadata property's values.
395 */
396USTRUCT()
398 GENERATED_USTRUCT_BODY()
399 /**
400 * @brief The semantic of this statistic.
401 */
402 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata|Statistics")
404
405 /**
406 * @brief The value of this statistic. This reflects the value on the tileset
407 * it is attached to and should not be edited by users.
408 */
409 UPROPERTY(Transient, VisibleAnywhere, Category = "Cesium|Metadata|Statistics")
411};
412
413/**
414 * @brief The statistics for a given metadata property.
415 */
416USTRUCT()
418 GENERATED_USTRUCT_BODY()
419 /**
420 * @brief The identifier of this property.
421 */
422 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata|Statistics")
423 FString Id;
424
425 /**
426 * @brief The available statistics for this property.
427 */
428 UPROPERTY(
429 EditAnywhere,
430 Category = "Cesium|Metadata|Statistics",
431 Meta = (TitleProperty = "Semantic"))
433};
434
435/**
436 * @brief The statistics for a given metadata class.
437 */
438USTRUCT()
440 GENERATED_USTRUCT_BODY()
441 /**
442 * @brief The identifier of this class.
443 */
444 UPROPERTY(EditAnywhere, Category = "Cesium|Metadata|Statistics")
445 FString Id;
446
447 /**
448 * @brief The statistics of properties belonging to this class.
449 */
450 UPROPERTY(
451 EditAnywhere,
452 Category = "Cesium|Metadata|Statistics",
453 Meta = (TitleProperty = "Id"))
455};
456
457#pragma endregion
458
459/**
460 * @brief Description of both feature IDs and metadata from a glTF via the
461 * EXT_mesh_features and EXT_structural_metadata extensions. Indicates what
462 * parts of the extension should be uploaded to the GPU for access in Unreal
463 * materials.
464 */
465USTRUCT()
466struct CESIUMRUNTIME_API FCesiumFeaturesMetadataDescription {
467 GENERATED_USTRUCT_BODY()
468
469public:
470 /**
471 * @brief Description of the statistics reported by the tileset. Each entry
472 * represents a class and its cumulative statistics.
473 */
474 UPROPERTY(EditAnywhere, Category = "Cesium", Meta = (TitleProperty = "Id"))
476
477 /**
478 * @brief Description of the feature ID sets available from the
479 * EXT_mesh_features or EXT_instance_features extensions in a glTF.
480 */
481 UPROPERTY(EditAnywhere, Category = "Cesium", Meta = (TitleProperty = "Name"))
483
484 /**
485 * @brief Description of the metadata used by the EXT_structural_metadata on a
486 * glTF's primitives.
487 */
488 UPROPERTY(EditAnywhere, Category = "Cesium", Meta = (TitleProperty = "Name"))
490
491 /**
492 * @brief Description of metadata from a glTF's EXT_structural_metadata
493 * extension.
494 */
495 UPROPERTY(EditAnywhere, Category = "Cesium", Meta = (TitleProperty = "Name"))
497};
@ UMETA
The tileset will be loaded from Cesium Ion using the provided IonAssetID and IonAccessToken.
ECesiumFeatureIdSetType
The type of a feature ID set.
@ Blueprint
Visual styles for each feature are evaluated in Blueprints before being passed to the generated mater...
@ Material
ECesiumMetadataStatisticSemantic
@ Mean
@ Median
@ StandardDeviation
@ Max
@ Variance
@ Min
@ Sum
Description of a feature ID set from either EXT_mesh_features or EXT_instance_features.
ECesiumFeatureStylingMode StylingMode
FString PropertyTableName
ECesiumFeatureIdSetType Type
FString Name
Description of both feature IDs and metadata from a glTF via the EXT_mesh_features and EXT_structural...
TArray< FCesiumMetadataClassStatisticsDescription > Statistics
FCesiumPrimitiveMetadataDescription PrimitiveMetadata
Description of the metadata used by the EXT_structural_metadata on a glTF's primitives.
FCesiumPrimitiveFeaturesDescription PrimitiveFeatures
Description of the feature ID sets available from the EXT_mesh_features or EXT_instance_features exte...
FCesiumModelMetadataDescription ModelMetadata
Description of metadata from a glTF's EXT_structural_metadata extension.
TArray< FCesiumMetadataPropertyStatisticsDescription > Properties
Describes how a property from EXT_structural_metadata will be encoded for access in Unreal materials.
Represents information about a metadata property according to how the property is defined in EXT_stru...
ECesiumMetadataStatisticSemantic Semantic
FCesiumMetadataValue Value
TArray< FCesiumMetadataPropertyStatisticValue > Values
Description of metadata from a glTF's EXT_structural_metadata extension that should be uploaded to th...
TArray< FCesiumPropertyTableDescription > PropertyTables
Descriptions of property tables to encode for access in Unreal materials.
TArray< FCesiumPropertyTextureDescription > PropertyTextures
Descriptions of property textures to make accessible to Unreal materials.
Description of the feature ID sets available from the EXT_mesh_features and EXT_instance_features ext...
TArray< FCesiumFeatureIdSetDescription > FeatureIdSets
Names of the metadata entities referenced by the EXT_structural_metadata on a glTF's primitives.
TSet< FString > PropertyTextureNames
The names of the property textures used by the glTF primitives across the tileset.
Description of a property attribute with properties that should be made accessible to Unreal material...
TArray< FCesiumPropertyAttributePropertyDescription > Properties
FString Name
Description of a property attribute property that should be encoded for access on the GPU.
FCesiumMetadataPropertyDetails PropertyDetails
Describes the underlying type of this property and other relevant information from its EXT_structural...
FCesiumMetadataEncodingDetails EncodingDetails
Description of a property table containing properties to be encoded for access in Unreal materials.
TArray< FCesiumPropertyTablePropertyDescription > Properties
FString Name
Description of a property table property that should be encoded for access on the GPU.
Description of a property texture with properties that should be made accessible to Unreal materials.
TArray< FCesiumPropertyTexturePropertyDescription > Properties
FString Name
Description of a property texture property that should be made accessible to Unreal materials.
