ICesiumVectorTilesStylingCallbacks Class Reference
#include <CesiumVectorTilesRasterOverlay.h>
void OnStylingBegin (const FCesiumModelMetadata &InModelMetadata)
 This function is called before styling begins.
virtual void OnStylingBegin_Implementation (const FCesiumModelMetadata &InModelMetadata)
bool OnStylePoint (int64 InFeatureId, const FVector &InPointLlh, FCesiumVectorPointStyle &OutPointStyle)
 This function is called for each individual point feature.
virtual bool OnStylePoint_Implementation (int64 InFeatureId, const FVector &InPointLlh, FCesiumVectorPointStyle &OutPointStyle)
bool OnStylePolyline (int64 InFeatureId, const TArray< FVector > &InPolylineLlh, FCesiumVectorLineStyle &OutLineStyle)
 This function is called for each individual polyline feature.
virtual bool OnStylePolyline_Implementation (int64 InFeatureId, const TArray< FVector > &InPolylineLlh, FCesiumVectorLineStyle &OutLineStyle)
bool OnStylePolygon (int64 InFeatureId, const TArray< FVector > &InPolygonLlh, FCesiumVectorPolygonStyle &OutPolygonStyle)
 This function is called for each individual polygon feature.
virtual bool OnStylePolygon_Implementation (int64 InFeatureId, const TArray< FVector > &InPolygonLlh, FCesiumVectorPolygonStyle &OutPolygonStyle)
Definition at line 37 of file CesiumVectorTilesRasterOverlay.h.
◆ OnStylePoint()
bool ICesiumVectorTilesStylingCallbacks::OnStylePoint ( int64 InFeatureId,
const FVector & InPointLlh,
FCesiumVectorPointStyle & OutPointStyle )
If it returns false, the default style will be used for this feature. If it returns true, the "Out Point Style" will be used for this feature.
◆ OnStylePoint_Implementation()
virtual bool ICesiumVectorTilesStylingCallbacks::OnStylePoint_Implementation ( int64 InFeatureId,
inlinevirtual
Definition at line 67 of file CesiumVectorTilesRasterOverlay.h.
◆ OnStylePolygon()
bool ICesiumVectorTilesStylingCallbacks::OnStylePolygon ( int64 InFeatureId,
const TArray< FVector > & InPolygonLlh,
FCesiumVectorPolygonStyle & OutPolygonStyle )
If it returns false, the default style will be used for this feature. If it returns true, the "Out Polygon Style" will be used for this feature.
◆ OnStylePolygon_Implementation()
virtual bool ICesiumVectorTilesStylingCallbacks::OnStylePolygon_Implementation ( int64 InFeatureId,
inlinevirtual
Definition at line 109 of file CesiumVectorTilesRasterOverlay.h.
◆ OnStylePolyline()
bool ICesiumVectorTilesStylingCallbacks::OnStylePolyline ( int64 InFeatureId,
const TArray< FVector > & InPolylineLlh,
FCesiumVectorLineStyle & OutLineStyle )
If it returns false, the default style will be used for this feature. If it returns true, the "Out Line Style" will be used for this feature.
◆ OnStylePolyline_Implementation()
virtual bool ICesiumVectorTilesStylingCallbacks::OnStylePolyline_Implementation ( int64 InFeatureId,
inlinevirtual
Definition at line 88 of file CesiumVectorTilesRasterOverlay.h.
◆ OnStylingBegin()
void ICesiumVectorTilesStylingCallbacks::OnStylingBegin ( const FCesiumModelMetadata & InModelMetadata)
It should be used to look up metadata property tables and store them for use in the styling functions.
◆ OnStylingBegin_Implementation()
virtual void ICesiumVectorTilesStylingCallbacks::OnStylingBegin_Implementation ( const FCesiumModelMetadata & InModelMetadata)
inlinevirtual
Definition at line 51 of file CesiumVectorTilesRasterOverlay.h.
