CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider Class Referenceabstract
A base class used for raster overlay providers that use a quadtree-based tiling scheme. This includes TileMapServiceRasterOverlay, BingMapsRasterOverlay, and WebMapServiceRasterOverlay. More...
#include <CesiumRasterOverlays/QuadtreeRasterOverlayTileProvider.h>
Inheritance diagram for CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider:
CesiumRasterOverlays::RasterOverlayTileProvider CesiumUtility::ReferenceCounted< T, false >
 QuadtreeRasterOverlayTileProvider (const CesiumUtility::IntrusivePointer< const RasterOverlay > &pCreator, const CreateRasterOverlayTileProviderParameters &parameters, const CesiumGeospatial::Projection &projection, const CesiumGeometry::QuadtreeTilingScheme &tilingScheme, const CesiumGeometry::Rectangle &coverageRectangle, uint32_t minimumLevel, uint32_t maximumLevel, uint32_t imageWidth, uint32_t imageHeight) noexcept
 Creates a new instance.
uint32_t getMinimumLevel () const noexcept
 Returns the minimum tile level of this instance.
uint32_t getMaximumLevel () const noexcept
 Returns the maximum tile level of this instance.
uint32_t getWidth () const noexcept
 Returns the image width of this instance, in pixels.
uint32_t getHeight () const noexcept
 Returns the image height of this instance, in pixels.
const CesiumGeometry::QuadtreeTilingScheme & getTilingScheme () const noexcept
 Returns the CesiumGeometry::QuadtreeTilingScheme of this instance.
uint32_t computeLevelFromTargetScreenPixels (const CesiumGeometry::Rectangle &rectangle, const glm::dvec2 &screenPixels)
 Computes the best quadtree level to use for an image intended to cover a given projected rectangle when it is a given size on the screen.
- Public Member Functions inherited from CesiumRasterOverlays::RasterOverlayTileProvider
 RasterOverlayTileProvider (const CesiumUtility::IntrusivePointer< const RasterOverlay > &pCreator, const CreateRasterOverlayTileProviderParameters &parameters, const CesiumGeospatial::Projection &projection, const CesiumGeometry::Rectangle &coverageRectangle) noexcept
virtual ~RasterOverlayTileProvider () noexcept
 Default destructor.
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent ()
 A future that resolves when this RasterOverlayTileProvider has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
RasterOverlay & getOwner () noexcept
 Returns the RasterOverlay that created this instance.
const RasterOverlay & getOwner () const noexcept
const RasterOverlayExternals & getExternals () const noexcept
 Get the external interfaces for use by the tile provider.
const std::shared_ptr< CesiumAsync::IAssetAccessor > & getAssetAccessor () const noexcept
 Get the system to use for asychronous requests and threaded work.
const std::shared_ptr< CesiumUtility::CreditSystem > & getCreditSystem () const noexcept
 Get the credit system that receives credits from this tile provider.
const CesiumAsync::AsyncSystem & getAsyncSystem () const noexcept
 Gets the async system used to do work in threads.
const std::shared_ptr< IPrepareRasterOverlayRendererResources > & getPrepareRendererResources () const noexcept
 Gets the interface used to prepare raster overlay images for rendering.
const std::shared_ptr< spdlog::logger > & getLogger () const noexcept
 Gets the logger to which to send messages about the tile provider and tiles.
const CesiumGeospatial::Projection & getProjection () const noexcept
 Returns the CesiumGeospatial::Projection of this instance.
const CesiumGeometry::Rectangle & getCoverageRectangle () const noexcept
 Returns the coverage CesiumGeometry::Rectangle of this instance.
const CesiumUtility::CreditSource & getCreditSource () const noexcept
 Gets the CesiumUtility::CreditSource that identifies this raster overlay's credits with the CesiumUtility::CreditSystem.
std::vector< CesiumUtility::Credit > & getCredits () noexcept
 Gets the collection of credits that should be shown whenever this tile provider is shown.
const std::vector< CesiumUtility::Credit > & getCredits () const noexcept
virtual void addCredits (CesiumUtility::CreditReferencer &creditReferencer) noexcept
 Adds this tile provider's credits to a credit referencer.
virtual void tick ()
 Called on a regular basis, such as once per frame. This can be implemented to perform operations such as polling that can't be easily handled with a Future.
void addReference () const
Protected Member Functions
virtual CesiumAsync::Future< LoadedRasterOverlayImage > loadQuadtreeTileImage (const CesiumGeometry::QuadtreeTileID &tileID) const =0
 Asynchronously loads a tile in the quadtree.
- Protected Member Functions inherited from CesiumRasterOverlays::RasterOverlayTileProvider
CesiumAsync::Future< LoadedRasterOverlayImage > loadTileImageFromUrl (const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers={}, LoadTileImageFromUrlOptions &&options={}) const
 Loads an image from a URL and optionally some request headers.
To implement a new raster overlay provider based on QuadtreeRasterOverlayTileProvider, use this as the base class and override loadQuadtreeTileImage with code that makes requests to your service.
Definition at line 31 of file QuadtreeRasterOverlayTileProvider.h.
◆ QuadtreeRasterOverlayTileProvider()
CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::QuadtreeRasterOverlayTileProvider ( const CesiumUtility::IntrusivePointer< const RasterOverlay > & pCreator,
const CreateRasterOverlayTileProviderParameters & parameters,
const CesiumGeospatial::Projection & projection,
const CesiumGeometry::QuadtreeTilingScheme & tilingScheme,
const CesiumGeometry::Rectangle & coverageRectangle,
uint32_t imageHeight )
noexcept
pCreatorThe RasterOverlay that directly created this instance. This will become the owner of this instance if another owner is not specified in CreateRasterOverlayTileProviderParameters::pOwner.
parametersThe parameters for creating the tile provider.
projectionThe CesiumGeospatial::Projection.
tilingSchemeThe tiling scheme to be used by this QuadtreeRasterOverlayTileProvider.
coverageRectangleThe rectangle that bounds all the area covered by this overlay, expressed in projected coordinates.
minimumLevelThe minimum quadtree tile level.
maximumLevelThe maximum quadtree tile level.
imageWidthThe image width.
imageHeightThe image height.
◆ computeLevelFromTargetScreenPixels()
uint32_t CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::computeLevelFromTargetScreenPixels ( const CesiumGeometry::Rectangle & rectangle,
const glm::dvec2 & screenPixels )
rectangleThe range of projected coordinates to cover.
screenPixelsThe number of screen pixels to be covered by the rectangle.
The level.
◆ getHeight()
uint32_t CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::getHeight ( ) const
inlinenoexcept
Definition at line 80 of file QuadtreeRasterOverlayTileProvider.h.
◆ getMaximumLevel()
uint32_t CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::getMaximumLevel ( ) const
inlinenoexcept
Definition at line 70 of file QuadtreeRasterOverlayTileProvider.h.
◆ getMinimumLevel()
uint32_t CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::getMinimumLevel ( ) const
inlinenoexcept
Definition at line 65 of file QuadtreeRasterOverlayTileProvider.h.
◆ getTilingScheme()
const CesiumGeometry::QuadtreeTilingScheme & CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::getTilingScheme ( ) const
inlinenoexcept
Definition at line 86 of file QuadtreeRasterOverlayTileProvider.h.
◆ getWidth()
uint32_t CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::getWidth ( ) const
inlinenoexcept
Definition at line 75 of file QuadtreeRasterOverlayTileProvider.h.
◆ loadQuadtreeTileImage()
virtual CesiumAsync::Future< LoadedRasterOverlayImage > CesiumRasterOverlays::QuadtreeRasterOverlayTileProvider::loadQuadtreeTileImage ( const CesiumGeometry::QuadtreeTileID & tileID) const
protectedpure virtual
tileIDThe ID of the quadtree tile to load.
A Future that resolves to the loaded image data or error information.
