cesium-native 0.67.0
Options for RasterOverlayTileProvider::loadTileImageFromUrl. More...
#include <CesiumRasterOverlays/RasterOverlayTileProvider.h>
| CesiumGeometry::Rectangle | rectangle {} |
| The rectangle definining the bounds of the image being loaded, expressed in the RasterOverlayTileProvider's projection. | |
| std::vector< CesiumUtility::Credit > | credits {} |
| The credits to display with this tile. | |
| bool | moreDetailAvailable = true |
| Whether more detailed data, beyond this image, is available within the bounds of this image. | |
| bool | allowEmptyImages = false |
| Whether empty (zero length) images are accepted as a valid response. | |
Definition at line 91 of file RasterOverlayTileProvider.h.
| bool CesiumRasterOverlays::LoadTileImageFromUrlOptions::allowEmptyImages = false |
If true, an otherwise valid response with zero length will be accepted as a valid 0x0 image. If false, such a response will be reported as an error.
ActivatedRasterOverlay::loadTile and ActivatedRasterOverlay::loadTileThrottled will treat such an image as "failed" and use the quadtree parent (or ancestor) image instead, but will not report any error.
This flag should only be set to true when the tile source uses a zero-length response as an indication that this tile is - as expected - not available.
Definition at line 129 of file RasterOverlayTileProvider.h.
| std::vector<CesiumUtility::Credit> CesiumRasterOverlays::LoadTileImageFromUrlOptions::credits {} |
This property is copied verbatim to the LoadedRasterOverlayImage::credits property.
Definition at line 104 of file RasterOverlayTileProvider.h.
| bool CesiumRasterOverlays::LoadTileImageFromUrlOptions::moreDetailAvailable = true |
Definition at line 110 of file RasterOverlayTileProvider.h.
| CesiumGeometry::Rectangle CesiumRasterOverlays::LoadTileImageFromUrlOptions::rectangle {} |
Definition at line 96 of file RasterOverlayTileProvider.h.
