CesiumRasterOverlays::LoadedRasterOverlayImage Struct Reference
Summarizes the result of loading an image of a RasterOverlay. More...
#include <CesiumRasterOverlays/RasterOverlayTileProvider.h>
 Returns the size of this LoadedRasterOverlayImage in bytes.
CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > pImage {nullptr}
 The loaded image.
CesiumGeometry::Rectangle rectangle {}
 The projected rectangle defining the bounds of this image.
std::vector< CesiumUtility::Credit > credits {}
 The CesiumUtility::Credit objects that decribe the attributions that are required when using the image.
CesiumUtility::ErrorList errorList {}
 Errors and warnings from loading the image.
bool moreDetailAvailable = false
 Whether more detailed data, beyond this image, is available within the bounds of this image.
Definition at line 37 of file RasterOverlayTileProvider.h.
int64_t CesiumRasterOverlays::LoadedRasterOverlayImage::getSizeBytes ( ) const
Definition at line 77 of file RasterOverlayTileProvider.h.
◆ credits
std::vector<CesiumUtility::Credit> CesiumRasterOverlays::LoadedRasterOverlayImage::credits {}
Definition at line 58 of file RasterOverlayTileProvider.h.
◆ errorList
CesiumUtility::ErrorList CesiumRasterOverlays::LoadedRasterOverlayImage::errorList {}
If the image was loaded successfully, there should not be any errors (but there may be warnings).
Definition at line 66 of file RasterOverlayTileProvider.h.
◆ moreDetailAvailable
bool CesiumRasterOverlays::LoadedRasterOverlayImage::moreDetailAvailable = false
Definition at line 72 of file RasterOverlayTileProvider.h.
◆ pImage
CesiumUtility::IntrusivePointer<CesiumImage::ImageAsset> CesiumRasterOverlays::LoadedRasterOverlayImage::pImage {nullptr}
The loaded image.
This will be nullptr if the loading failed. In this case, the errors vector will contain the corresponding error messages.
Definition at line 44 of file RasterOverlayTileProvider.h.
◆ rectangle
CesiumGeometry::Rectangle CesiumRasterOverlays::LoadedRasterOverlayImage::rectangle {}
The rectangle extends from the left side of the leftmost pixel to the right side of the rightmost pixel, and similar for the vertical direction.
Definition at line 52 of file RasterOverlayTileProvider.h.
