CesiumGeometry::QuadtreeTilingScheme Class Referencefinal
Defines how a rectangular region is divided into quadtree tiles. More...
#include <CesiumGeometry/QuadtreeTilingScheme.h>
 QuadtreeTilingScheme (const CesiumGeometry::Rectangle &rectangle, uint32_t rootTilesX, uint32_t rootTilesY) noexcept
const CesiumGeometry::Rectangle & getRectangle () const noexcept
 Return the overall rectangle that is tiled.
uint32_t getRootTilesX () const noexcept
 Returns the number of root tiles, in x-direction.
uint32_t getRootTilesY () const noexcept
 Returns the number of root tiles, in y-direction.
uint32_t getNumberOfXTilesAtLevel (uint32_t level) const noexcept
 Returns the number of tiles, in x-direction, at the given level.
uint32_t getNumberOfYTilesAtLevel (uint32_t level) const noexcept
 Returns the number of tiles, in y-direction, at the given level.
std::optional< CesiumGeometry::QuadtreeTileID > positionToTile (const glm::dvec2 &position, uint32_t level) const noexcept
 Computes the CesiumGeometry::QuadtreeTileID for a given position and level.
CesiumGeometry::Rectangle tileToRectangle (const CesiumGeometry::QuadtreeTileID &tileID) const noexcept
 Returns the CesiumGeometry::Rectangle that is covered by the specified tile.
Definition at line 16 of file QuadtreeTilingScheme.h.
◆ QuadtreeTilingScheme()
CesiumGeometry::QuadtreeTilingScheme::QuadtreeTilingScheme ( const CesiumGeometry::Rectangle & rectangle,
uint32_t rootTilesY )
noexcept
rectangleThe overall rectangle that is tiled, expressed in projected coordinates.
rootTilesXThe number of tiles at the root of the quadtree in the X direction.
rootTilesYThe number of tiles at the root of the quadtree in the Y direction.
◆ getRectangle()
const CesiumGeometry::Rectangle & CesiumGeometry::QuadtreeTilingScheme::getRectangle ( ) const
inlinenoexcept
The rectangle is expressed in projected coordinates.
Definition at line 38 of file QuadtreeTilingScheme.h.
◆ getRootTilesX()
uint32_t CesiumGeometry::QuadtreeTilingScheme::getRootTilesX ( ) const
inlinenoexcept
Definition at line 45 of file QuadtreeTilingScheme.h.
◆ getRootTilesY()
uint32_t CesiumGeometry::QuadtreeTilingScheme::getRootTilesY ( ) const
inlinenoexcept
Definition at line 50 of file QuadtreeTilingScheme.h.
◆ positionToTile()
std::optional< CesiumGeometry::QuadtreeTileID > CesiumGeometry::QuadtreeTilingScheme::positionToTile ( const glm::dvec2 & position,
uint32_t level ) const
noexcept
If the given position is within the getRectangle of this tiling scheme, then this will compute the quadtree tile ID for the tile that contains the given position at the given level. Otherwise, nullopt is returned.
positionThe 2D position
levelThe level
The tile ID, or nullopt.
◆ tileToRectangle()
CesiumGeometry::Rectangle CesiumGeometry::QuadtreeTilingScheme::tileToRectangle ( const CesiumGeometry::QuadtreeTileID & tileID) const
noexcept
The rectangle that is covered by the tile that is identified with the given CesiumGeometry::QuadtreeTileID will be computed, based on the getRectangle of this tiling scheme.
tileIDThe tile ID
The rectangle
