Base interface for all JSON handlers. Types that need to be deserialized from JSON should implement IJsonHandler or a class that derives from it. As the JSON is parsed, the corresponding read... method to the token that was parsed will be called. These methods can return themselves or a different handler to handle the value.
More...
#include <CesiumJsonReader/IJsonHandler.h>
| virtual IJsonHandler * | readNull ()=0 |
| virtual IJsonHandler * | readBool (bool b)=0 |
| virtual IJsonHandler * | readInt32 (int32_t i)=0 |
| virtual IJsonHandler * | readUint32 (uint32_t i)=0 |
| virtual IJsonHandler * | readInt64 (int64_t i)=0 |
| virtual IJsonHandler * | readUint64 (uint64_t i)=0 |
| virtual IJsonHandler * | readDouble (double d)=0 |
| virtual IJsonHandler * | readString (const std::string_view &str)=0 |
| virtual IJsonHandler * | readObjectStart ()=0 |
| virtual IJsonHandler * | readObjectKey (const std::string_view &str)=0 |
| virtual IJsonHandler * | readObjectEnd ()=0 |
| virtual IJsonHandler * | readArrayStart ()=0 |
| virtual IJsonHandler * | readArrayEnd ()=0 |
| virtual void | reportWarning (const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >())=0 |
Definition at line 18 of file IJsonHandler.h.
pure virtual |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, and CesiumJsonReader::JsonObjectJsonHandler.
pure virtual |
pure virtual |
| b | The boolean value. |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::BoolJsonHandler, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, and CesiumJsonReader::JsonObjectJsonHandler.
pure virtual |
| d | The double value. |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::DoubleJsonHandler, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::IntegerJsonHandler< T >, CesiumJsonReader::JsonHandler, and CesiumJsonReader::JsonObjectJsonHandler.
pure virtual |
| i | The int32 value. |
pure virtual |
| i | The int64 value. |
pure virtual |
pure virtual |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, CesiumJsonReader::JsonObjectJsonHandler, and CesiumJsonReader::ObjectJsonHandler.
pure virtual |
| str | The key. |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::DictionaryJsonHandler< T, THandler >, CesiumJsonReader::DictionaryJsonHandler< CesiumUtility::JsonValue, CesiumJsonReader::JsonObjectJsonHandler >, CesiumJsonReader::ExtensionsJsonHandler, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, and CesiumJsonReader::JsonObjectJsonHandler.
pure virtual |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, CesiumJsonReader::JsonObjectJsonHandler, and CesiumJsonReader::ObjectJsonHandler.
pure virtual |
| str | The string value. |
read... call. This can be the same handler as the current one. Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::JsonHandler, CesiumJsonReader::JsonObjectJsonHandler, and CesiumJsonReader::StringJsonHandler.
pure virtual |
| i | The uint32 value. |
pure virtual |
| i | The uint64 value. |
pure virtual |
| warning | The warning to report. |
| context | Context information to include with this warning to help debugging. |
Implemented in CesiumJsonReader::ArrayJsonHandler< T, THandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > >, CesiumJsonReader::IgnoreValueJsonHandler, CesiumJsonReader::IntegerJsonHandler< T >, CesiumJsonReader::JsonHandler, and CesiumJsonReader::ObjectJsonHandler.
