CesiumJsonReader::DoubleJsonHandler Class Reference
IJsonHandler for reading double values. More...
#include <CesiumJsonReader/DoubleJsonHandler.h>
Inheritance diagram for CesiumJsonReader::DoubleJsonHandler:
CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
void reset (IJsonHandler *pParent, double *pDouble)
 Resets the parent IJsonHandler of this handler, and the pointer to its destination double value.
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
virtual IJsonHandler * readObjectEnd () override
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
Definition at line 10 of file DoubleJsonHandler.h.
◆ readDouble()
virtual IJsonHandler * CesiumJsonReader::DoubleJsonHandler::readDouble ( double d)
overridevirtual
dThe double value.
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
◆ readInt32()
virtual IJsonHandler * CesiumJsonReader::DoubleJsonHandler::readInt32 ( int32_t i)
overridevirtual
iThe int32 value.
◆ readInt64()
virtual IJsonHandler * CesiumJsonReader::DoubleJsonHandler::readInt64 ( int64_t i)
overridevirtual
iThe int64 value.
◆ readUint32()
virtual IJsonHandler * CesiumJsonReader::DoubleJsonHandler::readUint32 ( uint32_t i)
overridevirtual
iThe uint32 value.
◆ readUint64()
virtual IJsonHandler * CesiumJsonReader::DoubleJsonHandler::readUint64 ( uint64_t i)
overridevirtual
iThe uint64 value.
