Reads the keys and values of a JSON object into a std::map<std::string, T> or an std::unordered_map<std::string, T>.
More...
#include <CesiumJsonReader/DictionaryJsonHandler.h>
| template<typename... Ts> | |
| DictionaryJsonHandler (Ts &&... args) noexcept | |
| Creates a new DictionaryJsonHandler, passing the specified arguments to the constructor of THandler. | |
| void | reset (IJsonHandler *pParent, std::unordered_map< std::string, T > *pDictionary) |
Resets the parent of this IJsonHandler and sets the destination pointer of this handler to an std::unordered_map<std::string, T>. | |
| void | reset (IJsonHandler *pParent, std::map< std::string, T > *pDictionary) |
Resets the parent of this IJsonHandler and sets the destination pointer of this handler to an std::map<std::string, T>. | |
| virtual IJsonHandler * | readObjectKey (const std::string_view &str) override |
Public Member Functions inherited from CesiumJsonReader::ObjectJsonHandler | |
| virtual IJsonHandler * | readObjectStart () override |
| virtual IJsonHandler * | readObjectEnd () override |
Public Member Functions inherited from CesiumJsonReader::JsonHandler | |
| virtual IJsonHandler * | readNull () override |
| virtual IJsonHandler * | readBool (bool b) override |
| virtual IJsonHandler * | readInt32 (int32_t i) override |
| virtual IJsonHandler * | readUint32 (uint32_t i) override |
| virtual IJsonHandler * | readInt64 (int64_t i) override |
| virtual IJsonHandler * | readUint64 (uint64_t i) override |
| virtual IJsonHandler * | readDouble (double d) override |
| virtual IJsonHandler * | readString (const std::string_view &str) override |
| virtual IJsonHandler * | readArrayStart () override |
| virtual IJsonHandler * | readArrayEnd () override |
Protected Member Functions inherited from CesiumJsonReader::ObjectJsonHandler | |
| virtual IJsonHandler * | StartSubObject () noexcept |
| Called when readObjectStart is called when the depth of the ObjectJsonHandler is greater than 0. | |
| virtual IJsonHandler * | EndSubObject () noexcept |
| Called when readObjectEnd is called when the depth of the ObjectJsonHandler is greater than 0. | |
| template<typename TAccessor, typename TProperty> | |
| IJsonHandler * | property (const char *currentKey, TAccessor &accessor, TProperty &value) |
| Called from IJsonHandler::readObjectKey to read a property into an object. | |
| const char * | getCurrentKey () const noexcept |
| Obtains the most recent key handled by this JsonHandler. | |
| virtual void | reportWarning (const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >()) override |
| void | setCurrentKey (const char *key) noexcept |
| Sets the most recent key handled by this JsonHandler. | |
Protected Member Functions inherited from CesiumJsonReader::JsonHandler | |
| void | reset (IJsonHandler *pParent) |
| Resets the parent IJsonHandler of this handler. | |
| IJsonHandler * | parent () |
| Obtains the parent IJsonHandler of this handler. | |
| IJsonHandler * | ignoreAndReturnToParent () |
| Ignore a single value and then return to the parent handler. | |
| IJsonHandler * | ignoreAndContinue () |
| Ignore a single value and the continue processing more tokens with this handler. | |
| T | The type of values in the map. |
| THandler | The type of the IJsonHandler to handle the map values. |
Definition at line 20 of file DictionaryJsonHandler.h.
inlinenoexcept |
Definition at line 27 of file DictionaryJsonHandler.h.
inlineoverridevirtual |
| str | The key. |
read... call. This can be the same handler as the current one. Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 57 of file DictionaryJsonHandler.h.
Definition at line 51 of file DictionaryJsonHandler.h.
reset twice on the same DictionaryJsonHandler, once with an std::map and once with an std::unordered_map. In practice, if a pointer to an std::unordered_map is present, it will always be used as the destination and the pointer to an std::map will be ignored. Definition at line 40 of file DictionaryJsonHandler.h.
