cesium-native 0.47.0
CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > > Class Template Reference
Special case of ArrayJsonHandler for reading arrays of arrays. Attempting to read other values will cause a warning. More...
#include <CesiumJsonReader/ArrayJsonHandler.h>
Inheritance diagram for CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >:
CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
Public Types
using ValueType = std::vector<T>
 The destination type.
template<typename... Ts>
 ArrayJsonHandler (Ts &&... args) noexcept
 Creates a new ArrayJsonHandler.
void reset (IJsonHandler *pParent, std::vector< std::vector< T > > *pArray)
 Resets the parent and destination array of this ArrayJsonHandler.
virtual IJsonHandlerreadNull () override
virtual IJsonHandlerreadBool (bool b) override
virtual IJsonHandlerreadInt32 (int32_t i) override
virtual IJsonHandlerreadUint32 (uint32_t i) override
virtual IJsonHandlerreadInt64 (int64_t i) override
virtual IJsonHandlerreadUint64 (uint64_t i) override
virtual IJsonHandlerreadDouble (double d) override
virtual IJsonHandlerreadString (const std::string_view &str) override
virtual IJsonHandlerreadObjectStart () override
virtual IJsonHandlerreadArrayStart () override
virtual IJsonHandlerreadArrayEnd () override
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
virtual IJsonHandlerreadObjectKey (const std::string_view &str) override
virtual IJsonHandlerreadObjectEnd () override
- Public Member Functions inherited from CesiumJsonReader::IJsonHandler
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandlerparent ()
IJsonHandlerignoreAndReturnToParent ()
IJsonHandlerignoreAndContinue ()
template<typename T, typename THandler>
class CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >
Template Parameters
TThe inner type of the nested array.
THandlerThe handler of the inner type of the array.
Definition at line 511 of file ArrayJsonHandler.h.
Member Typedef Documentation
◆ ValueType
template<typename T , typename THandler >
using CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::ValueType = std::vector<T>
Definition at line 516 of file ArrayJsonHandler.h.
◆ ArrayJsonHandler()
CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::ArrayJsonHandler ( Ts &&... args)
inlinenoexcept
argsThe arguments passed to the constructor of THandler when it's instantiated.
Definition at line 525 of file ArrayJsonHandler.h.
◆ readArrayEnd()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readArrayEnd ( )
inlineoverridevirtual
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 591 of file ArrayJsonHandler.h.
◆ readArrayStart()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readArrayStart ( )
Definition at line 578 of file ArrayJsonHandler.h.
◆ readBool()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readBool ( bool b)
bThe boolean value.
Definition at line 546 of file ArrayJsonHandler.h.
◆ readDouble()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readDouble ( double d)
dThe double value.
Definition at line 566 of file ArrayJsonHandler.h.
◆ readInt32()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readInt32 ( int32_t i)
iThe int32 value.
Definition at line 550 of file ArrayJsonHandler.h.
◆ readInt64()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readInt64 ( int64_t i)
iThe int64 value.
Definition at line 558 of file ArrayJsonHandler.h.
◆ readNull()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readNull ( )
Definition at line 542 of file ArrayJsonHandler.h.
◆ readObjectStart()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readObjectStart ( )
Definition at line 574 of file ArrayJsonHandler.h.
◆ readString()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readString ( const std::string_view & str)
strThe string value.
Definition at line 570 of file ArrayJsonHandler.h.
◆ readUint32()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readUint32 ( uint32_t i)
iThe uint32 value.
Definition at line 554 of file ArrayJsonHandler.h.
◆ readUint64()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::readUint64 ( uint64_t i)
iThe uint64 value.
Definition at line 562 of file ArrayJsonHandler.h.
◆ reportWarning()
virtual void CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::reportWarning ( const std::string & warning,
std::vector< std::string > && context = std::vector< std::string >() )
warningThe warning to report.
contextContext information to include with this warning to help debugging.
Definition at line 593 of file ArrayJsonHandler.h.
◆ reset()
void CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > >::reset ( IJsonHandler * pParent,
std::vector< std::vector< T > > * pArray )
Definition at line 535 of file ArrayJsonHandler.h.
