CesiumJsonReader::IgnoreValueJsonHandler Class Reference
IJsonHandler that does nothing but ignore the next value. More...
#include <CesiumJsonReader/IgnoreValueJsonHandler.h>
Inheritance diagram for CesiumJsonReader::IgnoreValueJsonHandler:
CesiumJsonReader::IJsonHandler
void reset (IJsonHandler *pParent) noexcept
 Resets the parent of this IJsonHandler.
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
virtual IJsonHandler * readObjectEnd () override
IJsonHandler * parent () noexcept
 Obtains the currently set parent of this handler, or nullptr if reset hasn't yet been called.
Each read... call will return the current parent of this JsonHandler, unless the value being read is an object or array, in which case it will continue until the object or array is ended before returning.
Definition at line 16 of file IgnoreValueJsonHandler.h.
◆ readArrayEnd()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readArrayEnd ( )
overridevirtual
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Implements CesiumJsonReader::IJsonHandler.
◆ readArrayStart()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readArrayStart ( )
overridevirtual
◆ readBool()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readBool ( bool b)
overridevirtual
bThe boolean value.
◆ readDouble()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readDouble ( double d)
overridevirtual
dThe double value.
◆ readInt32()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readInt32 ( int32_t i)
overridevirtual
iThe int32 value.
◆ readInt64()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readInt64 ( int64_t i)
overridevirtual
iThe int64 value.
◆ readNull()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readNull ( )
overridevirtual
◆ readObjectEnd()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readObjectEnd ( )
overridevirtual
◆ readObjectKey()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readObjectKey ( const std::string_view & str)
overridevirtual
strThe key.
◆ readObjectStart()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readObjectStart ( )
overridevirtual
◆ readString()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readString ( const std::string_view & str)
overridevirtual
strThe string value.
◆ readUint32()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readUint32 ( uint32_t i)
overridevirtual
iThe uint32 value.
◆ readUint64()
virtual IJsonHandler * CesiumJsonReader::IgnoreValueJsonHandler::readUint64 ( uint64_t i)
overridevirtual
iThe uint64 value.
◆ reportWarning()
virtual void CesiumJsonReader::IgnoreValueJsonHandler::reportWarning ( const std::string & warning,
std::vector< std::string > && context = std::vector< std::string >() )
overridevirtual
warningThe warning to report.
contextContext information to include with this warning to help debugging.
