cesium-native 0.67.0
Special case of ArrayJsonHandler for handling arrays of double values. This will read every scalar value as a double, regardless of whether it's floating point or not. Attempting to read other values will cause a warning. More...
#include <CesiumJsonReader/ArrayJsonHandler.h>
Public Types | |
| using | ValueType = std::vector<double> |
| The destination type. | |
| using | ValueType |
| void | reset (IJsonHandler *pParent, std::vector< double > *pArray) |
| Resets the parent and destination array of this ArrayJsonHandler. | |
| virtual IJsonHandler * | readNull () override |
| virtual IJsonHandler * | readBool (bool b) override |
| virtual IJsonHandler * | readInt32 (int32_t i) override |
| virtual IJsonHandler * | readUint32 (uint32_t i) override |
| virtual IJsonHandler * | readInt64 (int64_t i) override |
| virtual IJsonHandler * | readUint64 (uint64_t i) override |
| virtual IJsonHandler * | readDouble (double d) override |
| virtual IJsonHandler * | readString (const std::string_view &str) override |
| virtual IJsonHandler * | readObjectStart () override |
| virtual IJsonHandler * | readArrayStart () override |
| virtual IJsonHandler * | readArrayEnd () override |
| virtual void | reportWarning (const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >()) override |
| ArrayJsonHandler (Ts &&... args) noexcept | |
| Creates a new ArrayJsonHandler. | |
| virtual IJsonHandler * | readObjectKey (const std::string_view &str) noexcept override |
| virtual IJsonHandler * | readObjectEnd () noexcept override |
Protected Member Functions inherited from CesiumJsonReader::JsonHandler | |
| void | reset (IJsonHandler *pParent) |
| Resets the parent IJsonHandler of this handler. | |
| IJsonHandler * | parent () |
| Obtains the parent IJsonHandler of this handler. | |
| IJsonHandler * | ignoreAndReturnToParent () |
| Ignore a single value and then return to the parent handler. | |
| IJsonHandler * | ignoreAndContinue () |
| Ignore a single value and the continue processing more tokens with this handler. | |
Definition at line 324 of file ArrayJsonHandler.h.
| using CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >::ValueType |
Definition at line 27 of file ArrayJsonHandler.h.
| using CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler >::ValueType = std::vector<double> |
Definition at line 328 of file ArrayJsonHandler.h.
inlinenoexcept |
Definition at line 330 of file ArrayJsonHandler.h.
inlinenoexcept |
| args | The arguments that will be passed to the constructor of THandler when it's instantiated. |
Definition at line 36 of file ArrayJsonHandler.h.
inlineoverridevirtual |
read... call. This can be the same handler as the current one. Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 113 of file ArrayJsonHandler.h.
Definition at line 418 of file ArrayJsonHandler.h.
Definition at line 103 of file ArrayJsonHandler.h.
Definition at line 408 of file ArrayJsonHandler.h.
| b | The boolean value. |
Definition at line 57 of file ArrayJsonHandler.h.
Definition at line 346 of file ArrayJsonHandler.h.
| d | The double value. |
Definition at line 77 of file ArrayJsonHandler.h.
Definition at line 390 of file ArrayJsonHandler.h.
| i | The int32 value. |
Definition at line 61 of file ArrayJsonHandler.h.
Definition at line 350 of file ArrayJsonHandler.h.
| i | The int64 value. |
Definition at line 69 of file ArrayJsonHandler.h.
Definition at line 370 of file ArrayJsonHandler.h.
Definition at line 53 of file ArrayJsonHandler.h.
Definition at line 342 of file ArrayJsonHandler.h.
inlineoverridevirtualnoexcept |
Definition at line 101 of file ArrayJsonHandler.h.
| str | The key. |
Definition at line 96 of file ArrayJsonHandler.h.
Definition at line 85 of file ArrayJsonHandler.h.
Definition at line 404 of file ArrayJsonHandler.h.
| str | The string value. |
Definition at line 81 of file ArrayJsonHandler.h.
Definition at line 400 of file ArrayJsonHandler.h.
| i | The uint32 value. |
Definition at line 65 of file ArrayJsonHandler.h.
Definition at line 360 of file ArrayJsonHandler.h.
| i | The uint64 value. |
Definition at line 73 of file ArrayJsonHandler.h.
Definition at line 380 of file ArrayJsonHandler.h.
| warning | The warning to report. |
| context | Context information to include with this warning to help debugging. |
Definition at line 115 of file ArrayJsonHandler.h.
Definition at line 420 of file ArrayJsonHandler.h.
Definition at line 46 of file ArrayJsonHandler.h.
Definition at line 336 of file ArrayJsonHandler.h.
