CesiumJsonReader::ExtensionsJsonHandler Class Reference
IJsonHandler for reading extensions, such as those listed in an ExtensibleObject. More...
#include <CesiumJsonReader/ExtensionsJsonHandler.h>
Inheritance diagram for CesiumJsonReader::ExtensionsJsonHandler:
CesiumJsonReader::ObjectJsonHandler CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
 ExtensionsJsonHandler (const JsonReaderOptions &context) noexcept
 Creates a new ExtensionsJsonHandler with the specified reader options.
void reset (IJsonHandler *pParent, CesiumUtility::ExtensibleObject *pObject, const std::string &objectType)
 Resets the IJsonHandler's parent and pointer to destination, as well as the name of the object type that the extension is attached to.
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
- Public Member Functions inherited from CesiumJsonReader::ObjectJsonHandler
virtual IJsonHandler * readObjectEnd () override
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::ObjectJsonHandler
virtual IJsonHandler * StartSubObject () noexcept
 Called when readObjectStart is called when the depth of the ObjectJsonHandler is greater than 0.
virtual IJsonHandler * EndSubObject () noexcept
 Called when readObjectEnd is called when the depth of the ObjectJsonHandler is greater than 0.
template<typename TAccessor, typename TProperty>
IJsonHandler * property (const char *currentKey, TAccessor &accessor, TProperty &value)
 Called from IJsonHandler::readObjectKey to read a property into an object.
const char * getCurrentKey () const noexcept
 Obtains the most recent key handled by this JsonHandler.
void setCurrentKey (const char *key) noexcept
 Sets the most recent key handled by this JsonHandler.
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
Definition at line 15 of file ExtensionsJsonHandler.h.
◆ ExtensionsJsonHandler()
CesiumJsonReader::ExtensionsJsonHandler::ExtensionsJsonHandler ( const JsonReaderOptions & context)
inlineexplicitnoexcept
contextOptions to configure how the JSON is read.
Definition at line 23 of file ExtensionsJsonHandler.h.
◆ readObjectKey()
virtual IJsonHandler * CesiumJsonReader::ExtensionsJsonHandler::readObjectKey ( const std::string_view & str)
overridevirtual
strThe key.
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
