cesium-native 0.67.0
IJsonHandler for reading integer values. More...
#include <CesiumJsonReader/IntegerJsonHandler.h>
| void | reset (IJsonHandler *pParent, T *pInteger) |
| Resets the parent IJsonHandler of this instance and sets the pointer to its destination integer value. | |
| T * | getObject () |
| Obtains the integer pointer set on this handler by reset. | |
| virtual IJsonHandler * | readInt32 (int32_t i) override |
| virtual IJsonHandler * | readUint32 (uint32_t i) override |
| virtual IJsonHandler * | readInt64 (int64_t i) override |
| virtual IJsonHandler * | readUint64 (uint64_t i) override |
| virtual IJsonHandler * | readDouble (double d) override |
| virtual void | reportWarning (const std::string &warning, std::vector< std::string > &&context) override |
Public Member Functions inherited from CesiumJsonReader::JsonHandler | |
| virtual IJsonHandler * | readNull () override |
| virtual IJsonHandler * | readBool (bool b) override |
| virtual IJsonHandler * | readString (const std::string_view &str) override |
| virtual IJsonHandler * | readObjectStart () override |
| virtual IJsonHandler * | readObjectKey (const std::string_view &str) override |
| virtual IJsonHandler * | readObjectEnd () override |
| virtual IJsonHandler * | readArrayStart () override |
| virtual IJsonHandler * | readArrayEnd () override |
Protected Member Functions inherited from CesiumJsonReader::JsonHandler | |
| void | reset (IJsonHandler *pParent) |
| Resets the parent IJsonHandler of this handler. | |
| IJsonHandler * | parent () |
| Obtains the parent IJsonHandler of this handler. | |
| IJsonHandler * | ignoreAndReturnToParent () |
| Ignore a single value and then return to the parent handler. | |
| IJsonHandler * | ignoreAndContinue () |
| Ignore a single value and the continue processing more tokens with this handler. | |
Definition at line 19 of file IntegerJsonHandler.h.
inlinenoexcept |
Definition at line 21 of file IntegerJsonHandler.h.
Definition at line 35 of file IntegerJsonHandler.h.
inlineoverridevirtual |
| d | The double value. |
read... call. This can be the same handler as the current one. Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 62 of file IntegerJsonHandler.h.
| i | The int32 value. |
Definition at line 38 of file IntegerJsonHandler.h.
| i | The int64 value. |
Definition at line 50 of file IntegerJsonHandler.h.
| i | The uint32 value. |
Definition at line 44 of file IntegerJsonHandler.h.
| i | The uint64 value. |
Definition at line 56 of file IntegerJsonHandler.h.
| warning | The warning to report. |
| context | Context information to include with this warning to help debugging. |
Definition at line 89 of file IntegerJsonHandler.h.
Definition at line 27 of file IntegerJsonHandler.h.
