CesiumJsonReader::JsonHandler Class Reference
A dummy implementation of IJsonHandler that will report a warning and return its parent when any of its read... methods are called. More...
#include <CesiumJsonReader/JsonHandler.h>
Inheritance diagram for CesiumJsonReader::JsonHandler:
CesiumJsonReader::IJsonHandler CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler > CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > > CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler > CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler > CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > > CesiumJsonReader::ArrayJsonHandler< T, THandler > CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler > CesiumJsonReader::ArrayJsonHandler< T, IntegerJsonHandler< T > > CesiumJsonReader::ArrayJsonHandler< double, DoubleJsonHandler > CesiumJsonReader::ArrayJsonHandler< std::string, StringJsonHandler > CesiumJsonReader::ArrayJsonHandler< std::vector< T >, ArrayJsonHandler< T, THandler > > CesiumJsonReader::BoolJsonHandler CesiumJsonReader::DoubleJsonHandler CesiumJsonReader::IntegerJsonHandler< T > CesiumJsonReader::JsonObjectJsonHandler CesiumJsonReader::ObjectJsonHandler CesiumJsonReader::StringJsonHandler
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
virtual IJsonHandler * readObjectEnd () override
Protected Member Functions
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
This class can be used as a base for any specialized JsonHandlers, overriding the methods required for the value you're handling and leaving the rest to report warnings if called.
Definition at line 19 of file JsonHandler.h.
◆ readArrayEnd()
◆ readArrayStart()
◆ readBool()
◆ readDouble()
◆ readInt32()
◆ readInt64()
◆ readNull()
◆ readObjectEnd()
◆ readObjectKey()
◆ readObjectStart()
◆ readString()
◆ readUint32()
◆ readUint64()
◆ reportWarning()
