CesiumJsonReader::ObjectJsonHandler Class Reference
IJsonHandler for handling JSON objects. More...
#include <CesiumJsonReader/ObjectJsonHandler.h>
Inheritance diagram for CesiumJsonReader::ObjectJsonHandler:
CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler CesiumJsonReader::DictionaryJsonHandler< CesiumUtility::JsonValue, CesiumJsonReader::JsonObjectJsonHandler > CesiumJsonReader::DictionaryJsonHandler< T, THandler > CesiumJsonReader::ExtensibleObjectJsonHandler CesiumJsonReader::ExtensionsJsonHandler CesiumJsonReader::SharedAssetJsonHandler
virtual IJsonHandler * readObjectEnd () override
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
Protected Member Functions
virtual IJsonHandler * StartSubObject () noexcept
 Called when readObjectStart is called when the depth of the ObjectJsonHandler is greater than 0.
virtual IJsonHandler * EndSubObject () noexcept
 Called when readObjectEnd is called when the depth of the ObjectJsonHandler is greater than 0.
template<typename TAccessor, typename TProperty>
IJsonHandler * property (const char *currentKey, TAccessor &accessor, TProperty &value)
 Called from IJsonHandler::readObjectKey to read a property into an object.
const char * getCurrentKey () const noexcept
 Obtains the most recent key handled by this JsonHandler.
void setCurrentKey (const char *key) noexcept
 Sets the most recent key handled by this JsonHandler.
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
Definition at line 13 of file ObjectJsonHandler.h.
◆ ObjectJsonHandler()
CesiumJsonReader::ObjectJsonHandler::ObjectJsonHandler ( )
inlinenoexcept
Definition at line 15 of file ObjectJsonHandler.h.
◆ property()
IJsonHandler * CesiumJsonReader::ObjectJsonHandler::property ( const char * currentKey,
TAccessor & accessor,
TProperty & value )
inlineprotected
currentKeyThe key that's currently being read.
accessorAn IJsonHandler that can read the type of this property.
valueA reference to the location to store the read value.
The accessor IJsonHandler that will read the next token into value.
Definition at line 47 of file ObjectJsonHandler.h.
◆ readObjectEnd()
virtual IJsonHandler * CesiumJsonReader::ObjectJsonHandler::readObjectEnd ( )
overridevirtual
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
◆ readObjectStart()
virtual IJsonHandler * CesiumJsonReader::ObjectJsonHandler::readObjectStart ( )
overridevirtual
◆ reportWarning()
virtual void CesiumJsonReader::ObjectJsonHandler::reportWarning ( const std::string & warning,
std::vector< std::string > && context = std::vector< std::string >() )
overrideprotectedvirtual
warningThe warning to report.
contextContext information to include with this warning to help debugging.
