CesiumJsonReader::ArrayJsonHandler< T, THandler > Class Template Reference
IJsonHandler for reading a JSON array into an std::vector. More...
#include <CesiumJsonReader/ArrayJsonHandler.h>
Inheritance diagram for CesiumJsonReader::ArrayJsonHandler< T, THandler >:
CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
Public Types
using ValueType = std::vector<T>
 The destination type.
template<typename... Ts>
 ArrayJsonHandler (Ts &&... args) noexcept
 Creates a new ArrayJsonHandler.
void reset (IJsonHandler *pParent, std::vector< T > *pArray)
 Resets the parent and destination array of this ArrayJsonHandler.
virtual IJsonHandler * readObjectKey (const std::string_view &str) noexcept override
virtual IJsonHandler * readObjectEnd () noexcept override
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
template<typename T, typename THandler>
class CesiumJsonReader::ArrayJsonHandler< T, THandler >
Template Parameters
TThe element type of the destination vector.
THandlerThe IJsonHandler to handle each element.
Definition at line 24 of file ArrayJsonHandler.h.
Member Typedef Documentation
◆ ValueType
using CesiumJsonReader::ArrayJsonHandler< T, THandler >::ValueType = std::vector<T>
Definition at line 27 of file ArrayJsonHandler.h.
◆ ArrayJsonHandler()
CesiumJsonReader::ArrayJsonHandler< T, THandler >::ArrayJsonHandler ( Ts &&... args)
inlinenoexcept
argsThe arguments that will be passed to the constructor of THandler when it's instantiated.
Definition at line 36 of file ArrayJsonHandler.h.
◆ readArrayEnd()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readArrayEnd ( )
inlineoverridevirtual
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 113 of file ArrayJsonHandler.h.
◆ readArrayStart()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readArrayStart ( )
Definition at line 103 of file ArrayJsonHandler.h.
◆ readBool()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readBool ( bool b)
bThe boolean value.
Definition at line 57 of file ArrayJsonHandler.h.
◆ readDouble()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readDouble ( double d)
dThe double value.
Definition at line 77 of file ArrayJsonHandler.h.
◆ readInt32()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readInt32 ( int32_t i)
iThe int32 value.
Definition at line 61 of file ArrayJsonHandler.h.
◆ readInt64()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readInt64 ( int64_t i)
iThe int64 value.
Definition at line 69 of file ArrayJsonHandler.h.
◆ readNull()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readNull ( )
Definition at line 53 of file ArrayJsonHandler.h.
◆ readObjectEnd()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readObjectEnd ( )
inlineoverridevirtualnoexcept
Definition at line 101 of file ArrayJsonHandler.h.
◆ readObjectKey()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readObjectKey ( const std::string_view & str)
strThe key.
Definition at line 96 of file ArrayJsonHandler.h.
◆ readObjectStart()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readObjectStart ( )
Definition at line 85 of file ArrayJsonHandler.h.
◆ readString()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readString ( const std::string_view & str)
strThe string value.
Definition at line 81 of file ArrayJsonHandler.h.
◆ readUint32()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readUint32 ( uint32_t i)
iThe uint32 value.
Definition at line 65 of file ArrayJsonHandler.h.
◆ readUint64()
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< T, THandler >::readUint64 ( uint64_t i)
iThe uint64 value.
Definition at line 73 of file ArrayJsonHandler.h.
◆ reportWarning()
virtual void CesiumJsonReader::ArrayJsonHandler< T, THandler >::reportWarning ( const std::string & warning,
std::vector< std::string > && context = std::vector< std::string >() )
warningThe warning to report.
contextContext information to include with this warning to help debugging.
Definition at line 115 of file ArrayJsonHandler.h.
◆ reset()
void CesiumJsonReader::ArrayJsonHandler< T, THandler >::reset ( IJsonHandler * pParent,
std::vector< T > * pArray )
Definition at line 46 of file ArrayJsonHandler.h.
