IJsonHandler.h
3#include <CesiumJsonReader/Library.h>
5#include <cstdint>
6#include <string>
7#include <string_view>
8#include <vector>
9
10namespace CesiumJsonReader {
18class CESIUMJSONREADER_API IJsonHandler {
19public:
20 virtual ~IJsonHandler() = default;
26 virtual IJsonHandler* readNull() = 0;
33 virtual IJsonHandler* readBool(bool b) = 0;
40 virtual IJsonHandler* readInt32(int32_t i) = 0;
47 virtual IJsonHandler* readUint32(uint32_t i) = 0;
54 virtual IJsonHandler* readInt64(int64_t i) = 0;
61 virtual IJsonHandler* readUint64(uint64_t i) = 0;
68 virtual IJsonHandler* readDouble(double d) = 0;
75 virtual IJsonHandler* readString(const std::string_view& str) = 0;
76
90 virtual IJsonHandler* readObjectKey(const std::string_view& str) = 0;
97
110
118 virtual void reportWarning(
119 const std::string& warning,
120 std::vector<std::string>&& context = std::vector<std::string>()) = 0;
121};
122} // namespace CesiumJsonReader
virtual IJsonHandler * readArrayEnd()=0
virtual IJsonHandler * readArrayStart()=0
virtual IJsonHandler * readUint32(uint32_t i)=0
virtual IJsonHandler * readObjectKey(const std::string_view &str)=0
virtual IJsonHandler * readUint64(uint64_t i)=0
virtual IJsonHandler * readNull()=0
virtual IJsonHandler * readObjectEnd()=0
virtual IJsonHandler * readDouble(double d)=0
virtual IJsonHandler * readBool(bool b)=0
virtual void reportWarning(const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >())=0
virtual IJsonHandler * readObjectStart()=0
virtual IJsonHandler * readString(const std::string_view &str)=0
virtual IJsonHandler * readInt64(int64_t i)=0
virtual IJsonHandler * readInt32(int32_t i)=0
Classes for reading JSON.
