cesium-native 0.67.0
IJsonHandler for reading string values. More...
#include <CesiumJsonReader/StringJsonHandler.h>
| void | reset (IJsonHandler *pParent, std::string *pString) |
| Resets the parent IJsonHandler of this handler, and the pointer to its destination string value. | |
| std::string * | getObject () noexcept |
| Obtains the pointer to the current destination string value of this handler. | |
| virtual IJsonHandler * | readString (const std::string_view &str) override |
Public Member Functions inherited from CesiumJsonReader::JsonHandler | |
| virtual IJsonHandler * | readNull () override |
| virtual IJsonHandler * | readBool (bool b) override |
| virtual IJsonHandler * | readInt32 (int32_t i) override |
| virtual IJsonHandler * | readUint32 (uint32_t i) override |
| virtual IJsonHandler * | readInt64 (int64_t i) override |
| virtual IJsonHandler * | readUint64 (uint64_t i) override |
| virtual IJsonHandler * | readDouble (double d) override |
| virtual IJsonHandler * | readObjectStart () override |
| virtual IJsonHandler * | readObjectKey (const std::string_view &str) override |
| virtual IJsonHandler * | readObjectEnd () override |
| virtual IJsonHandler * | readArrayStart () override |
| virtual IJsonHandler * | readArrayEnd () override |
| virtual void | reportWarning (const std::string &warning, std::vector< std::string > &&context=std::vector< std::string >()) override |
Protected Member Functions inherited from CesiumJsonReader::JsonHandler | |
| void | reset (IJsonHandler *pParent) |
| Resets the parent IJsonHandler of this handler. | |
| IJsonHandler * | parent () |
| Obtains the parent IJsonHandler of this handler. | |
| IJsonHandler * | ignoreAndReturnToParent () |
| Ignore a single value and then return to the parent handler. | |
| IJsonHandler * | ignoreAndContinue () |
| Ignore a single value and the continue processing more tokens with this handler. | |
Definition at line 12 of file StringJsonHandler.h.
overridevirtual |
| str | The string value. |
read... call. This can be the same handler as the current one. Reimplemented from CesiumJsonReader::JsonHandler.
