CesiumJsonReader::JsonObjectJsonHandler Class Reference
IJsonHandler for arbitrary CesiumUtility::JsonValue JsonValue objects. More...
#include <CesiumJsonReader/JsonObjectJsonHandler.h>
Inheritance diagram for CesiumJsonReader::JsonObjectJsonHandler:
CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
Public Types
using ValueType = CesiumUtility::JsonValue
 The type of value this handler produces.
void reset (IJsonHandler *pParent, CesiumUtility::JsonValue *pValue)
 Resets this IJsonHandler's parent handler, as well as its destination pointer.
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
virtual IJsonHandler * readObjectEnd () override
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
Definition at line 13 of file JsonObjectJsonHandler.h.
Member Typedef Documentation
◆ ValueType
Definition at line 18 of file JsonObjectJsonHandler.h.
◆ readArrayEnd()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readArrayEnd ( )
overridevirtual
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
◆ readArrayStart()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readArrayStart ( )
overridevirtual
◆ readBool()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readBool ( bool b)
overridevirtual
bThe boolean value.
◆ readDouble()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readDouble ( double d)
overridevirtual
dThe double value.
◆ readInt32()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readInt32 ( int32_t i)
overridevirtual
iThe int32 value.
◆ readInt64()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readInt64 ( int64_t i)
overridevirtual
iThe int64 value.
◆ readNull()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readNull ( )
overridevirtual
◆ readObjectEnd()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readObjectEnd ( )
overridevirtual
◆ readObjectKey()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readObjectKey ( const std::string_view & str)
overridevirtual
strThe key.
◆ readObjectStart()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readObjectStart ( )
overridevirtual
◆ readString()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readString ( const std::string_view & str)
overridevirtual
strThe string value.
◆ readUint32()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readUint32 ( uint32_t i)
overridevirtual
iThe uint32 value.
◆ readUint64()
virtual IJsonHandler * CesiumJsonReader::JsonObjectJsonHandler::readUint64 ( uint64_t i)
overridevirtual
iThe uint64 value.
